Home > Td5 > TD5 miss fire after 15 seconds and hot relay ? |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2056 |
Wouldn't have thought the relay should be hot to touch.
Mine certainly isn't. Mind you, it is worth you giving them all the once over including their bases/connections. A loose/poor connection can cause a high resistance and therefore get hot. That said, I'm only responding to the relay observation, not the overall symptoms |
21st Oct 2015 9:01pm |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
From my experience relays do get warm if they are activated for more than a minute or so, even without current passing through..
Not saying it isn't the relay, always worth trying a new one just to be sure |
21st Oct 2015 9:29pm |
Crs90 Member Since: 08 Jul 2015 Location: In my excavator Posts: 82 |
New relays and injector wiring loom on their way so will report back after they are fitted.
Chris |
22nd Oct 2015 3:01pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
As my relays are between my seats now to increase the possible water level, I will feel my relays tonight when I drive back. I expect them to be cold or cool, not hot.
So I think it might be the relay. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
22nd Oct 2015 4:14pm |
One off the relays get hand warm, not hot after a 20 minute drive. Roel
24th Oct 2015 2:36pm |
Thanks for the replies everyone.
Today I fitted the new relays and didn't make any difference so fitted the new injector loom and all seems well now, off on a trip out tomorrow so hopefully will be all ok. Cheers Chris. |
24th Oct 2015 7:32pm |
