![]() | Home > Puma (Tdci) > Clutch not engaging |
110-Utility Member Since: 30 Sep 2015 Location: Devon Posts: 47 ![]() ![]() ![]() |
The hydraulic clutch fluid reservoir is bone dry, so a chance the system ran dry and now isn't enough pressure to engage, or when the car stalled it split/popped something and it's drained
I've been underneath and can't see any fresh fluid however |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
LR assist is your friend....master or slave cylinder or pipe in between.
LR assist?
What's that and if you mean the Land Rover breakdown, it won't cover my 2008 defender will it? |
As has been said master or slave cylinder or the pipework has leaked somewhere, you may get a bit of pedal back by refilling with appropriate fluid and bleeding but it will only be a temporary fix until the fault is rectified.
If it's the slave it's a gearbox out job i'm afraid and best replace the master while you are at it too. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
sorry thought you had a newer one.
crawl underneath and take a look. |
Best we can work out is the slave cylinder has gone.
Going to get it flat bedded somewhere to be fixed. Any ideas what I can expect the bill to be? Thanks |
£700-£1000 plus going by the thread below!
![]() http://www.defender2.net/forum/topic30979.html?highlight=clutch If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 ![]() ![]() ![]() |
I paid £940 for a new slave and clutch kit using genuine LR parts. Deduct about £300 from that if you don't want to change the clutch. My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
miket Member Since: 05 Oct 2012 Location: Peak District Posts: 143 ![]() |
Interesting - was that at a main dealer or an independent?
To wrap this up, I took the car to Safari engineering (defender specialist) and collected it yesterday.
The previous owner replaced the clutch with a upgraded 2.2 clutch last year but installed a aftermarket slave cylinder that according to safari was a much weaker part. Because of this it was the weakest link and went. Clutch was fine, so gearbox out to replace the slave with a genuine LR part and it was fixed. Bill was £637, and was very impressed with safari. |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
£700 equivalent (NZ dollars) to get slave replaced and clutch and bearing while we were at it (when in 'rome'!)
I opted for the OEM parts... I did the master myself initially, parts cost only which was minimal - pity it didn't solve it. |
