Home > Puma (Tdci) > Clutch not engaging
110-Utility
United Kingdom 2008 Defender 110 Puma 2.4 USW Corris Grey
Clutch not engaging
Drove my defender this morning no problems, clutch not slipping in the slightest
Made the mistake of leaving it in gear and Just started the car up and with a bit of a shudder it stalled.
However then when I tried to re-start it the clutch is not engaging at all, it springs to the floor and has to be manually pulled back up by hand.
It's only operating on the spring and no hydrolics seem to be engaging at all.
Any ideas?
Only had it two weeks, the wife won't be impressed Laughing
Thanks
Post #464031 17th Oct 2015 1:25pm
110-Utility
The hydraulic clutch fluid reservoir is bone dry, so a chance the system ran dry and now isn't enough pressure to engage, or when the car stalled it split/popped something and it's drained
I've been underneath and can't see any fresh fluid however
Post #464035 17th Oct 2015 1:38pm
T1G UP
LR assist is your friend....master or slave cylinder or pipe in between.
Post #464068 17th Oct 2015 3:34pm
110-Utility
LR assist?
What's that and if you mean the Land Rover breakdown, it won't cover my 2008 defender will it?
Post #464071 17th Oct 2015 3:54pm
Happyoldgit
As has been said master or slave cylinder or the pipework has leaked somewhere, you may get a bit of pedal back by refilling with appropriate fluid and bleeding but it will only be a temporary fix until the fault is rectified.
If it's the slave it's a gearbox out job i'm afraid and best replace the master while you are at it too. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #464075 17th Oct 2015 4:17pm
T1G UP
sorry thought you had a newer one.
crawl underneath and take a look.
Post #464081 17th Oct 2015 4:52pm
110-Utility
Best we can work out is the slave cylinder has gone.
Going to get it flat bedded somewhere to be fixed.
Any ideas what I can expect the bill to be?
Thanks
Post #464255 18th Oct 2015 10:11am
K9F
£700-£1000 plus going by the thread below! Big Cry
http://www.defender2.net/forum/topic30979.html?highlight=clutch If you go through life with your head in the sand....all people will see is an ar5e!!
Post #464271 18th Oct 2015 11:27am
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
I paid £940 for a new slave and clutch kit using genuine LR parts. Deduct about £300 from that if you don't want to change the clutch. My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #465705 23rd Oct 2015 8:25am
miket
Interesting - was that at a main dealer or an independent?
Post #465706 23rd Oct 2015 8:28am
110-Utility
To wrap this up, I took the car to Safari engineering (defender specialist) and collected it yesterday.
The previous owner replaced the clutch with a upgraded 2.2 clutch last year but installed a aftermarket slave cylinder that according to safari was a much weaker part. Because of this it was the weakest link and went.
Clutch was fine, so gearbox out to replace the slave with a genuine LR part and it was fixed.
Bill was £637, and was very impressed with safari.
Post #465710 23rd Oct 2015 8:38am
agentmulder
Kuwait
£700 equivalent (NZ dollars) to get slave replaced and clutch and bearing while we were at it (when in 'rome'!)
I opted for the OEM parts...
I did the master myself initially, parts cost only which was minimal - pity it didn't solve it.
Post #528417 2nd May 2016 2:04am
