Home > Puma (Tdci) > Chassis corrosion on newly delivered 110...!
Page 2 of 3 <123>
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
If that's all there is, you're pretty lucky. Most are worse: mine was, even the dealer's show-room exhibited one was up on a ramp with the corrosion and rust (the track-rod ends were uniformly brown) for all to see. Defenders are what they are.
Mainly commenting on “whom I should bequeath mine too want too keep it until I die”. House too? Wife? I'm hoping to upgrade all three several times before I pop my clogs and if, when I die, there's anything left over in the bank I obviously haven't budgeted very well.
I did just ask my (third) wife and son what they'd do if they were bequeathed my Defender and Morgan: missus says she'd sell 'em both and buy a Porsche, son says he'd sell 'em both and buy a motorbike (he's got his own car). If I were to ask my daughters they'd probably say “sell 'em both and go on holiday”.
Peter
Edited to add: probably should now be saying: "Defenders were what they were"
Post #465450 22nd Oct 2015 11:59am
Nipalong
England 2015 Defender 90 Puma 2.2 SW Corris Grey
I have sprayed my chassis with old engine old, if you look under rather, where there is an oil leak there is no rust. Cheap and easy,
Post #465456 22nd Oct 2015 12:15pm
That was an old, and once very popular, treatment, but it has some significant disadvantages:
- It is filthy, and attracts dirt, dust, grit and grot like nothing else
- It makes it hard to spot oil leaks
- The oil gets into a lot of places it shouldn't including electrical connectors
- It is likely to rot any rubber parts it comes into contact with
- It is almost certainly illegal now on environmental grounds
- Engine oil is harmful to health by contact and inhallation.
There are many better products available now for the purpose.
Post #465464 22nd Oct 2015 12:31pm
X4SKP
-It is also dangerous for other road users particularly those on 2 wheels, rain soaked roads,
will progressively wash off the oil leaving an oily film on the road surface...
-It is also highly flammable... SKIP
Post #465480 22nd Oct 2015 1:05pm
Griff_L322
Wales 2015 Defender 90 Puma 2.2 HT Corris Grey
this is unfortunately normal, this is why we underseal!
Post #465485 22nd Oct 2015 1:33pm
Jukathy
2012 Defender 110 Puma 2.2 SW Keswick Green
I'd bet almost anything that my good old 2CV came with slightly corrosive welds, too.
Anyhow, rust problems usually occur in humid corners not on flat steel plates that dry quickly.
But, if you're going to get any relevant information - let me know, I'm interested. Thumbs Up
By the way: I'm also keen on surviving my dogs and men - living together - forever - with my good old 110 in perfect harmony Laughing
Post #465616 22nd Oct 2015 8:45pm
LR90XS2011
QUOTE "Mainly commenting on “whom I should bequeath mine too want too keep it until I die”. House too? Wife? I'm hoping to upgrade all three several times before I pop my clogs and if, when I die, there's anything left over in the bank I obviously haven't budgeted very well.
Peter"
LOL i am on my second wife and second defender happy with both and cant afford to upgrade either unless I have a lotto win DEFENDER 90 TDCI XS,
Post #465617 22nd Oct 2015 8:50pm
Cuthbert
The chassis itself is fabricated from mild steel sections welded together and then given a fairly light black coating to offer a degree of protection. Land Rover have had many years to improve both the protective and cosmetic qualities of the finish but have chosen a more 'value-engineered' solution. They could have offered hot dipped zinc galvanised chassis as standard many years ago - but have chosen not to.
Those with a background in engineering will know that welded joints are a weak point in terms of corrosion protection, even with thorough post-weld surface prepping. For those who study the rear cross-members of fairly new Defenders - corrosion and a poor cosmetic finish are not unknown. If you really want to see a quickly deteriorating chassis - check out a (dairy) farmer's Defender.
At best all you can do is slow down the inevitable rust appearing - that is where a broad range of commercial 'products' comes into play. Each of these products has a following of disciples, many of whom believe that their chosen product is 'the only one'.
On my last visit to Solihull I noted and commented that they were assembling new Defenders on chassis' that were faded almost grey (not fresh black) - obviously been exposed to the elements for a lengthy period prior to arriving at the assembly line. Our Land Rover man said the oxidised finish could easily be freshened up with a polish.
The chassis manufacturer does not appear to wrap/protect the chassis for transportation (to save the planet and cut costs) and exposure to the elements seems inevitable - all before the vehicle is built.
As for other parts on the underside rusting - bare metal (non-alloy) castings and threaded parts quickly rust.
Post #465682 22nd Oct 2015 11:23pm
Cuthbert
Painting or spraying engine oil onto the underside of your Defender wouldn't get you a 'Save the Planet' award and is a rather out-dated approach. I'm not sure about it being "highly flammable" ...
Post #465683 22nd Oct 2015 11:29pm
ericvv
Shocked Shocking that some people still do that today. No less than criminal I'd say. If you would do that here, and go like that to the tech inspection, equivalent of your MOT, you would not even drive out from there anymore, your truck would be impounded on the spot, with all consequential costs for your account. Right approach too.
Maybe you also emptied the rest of your used motor oil recipient into the sewers? Cheap and easy too. Rolling Eyes You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #465695 23rd Oct 2015 6:34am
familymad
Most of my 110's have the 'auto oil' system fitted to the vehicle. It tends to spray the chassis with oil without request. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #465698 23rd Oct 2015 7:00am
ericvv
^^ Also interesting. And you pass your annual MOT like that?
Different countries, different ideas about environment clearly.
Here, in order to present your car to the periodic tech inspection, both engine/engine compartment and entire chassis have to be spic and span shiny clean. So you would not even be able to hide an eventual small oil leak. And any small oil leak means a fail. If you do not correct this and have it reinspected within the time allowed, tech inspection will inform registration office, who will send you a letter to turn in your license plates....
Not too many dirty cars on the road here, except the French commuters. Laughing
Post #465740 23rd Oct 2015 10:41am
jimbob7
/\/\/\ Sarcasm dude,he means the factory fitted oil leaks defenders come with,hahaha.
Imo,the best way to deal with the chassis is to paint it,with Rustoleum/POR,which is 50 times tougher than the landrovers afterthought and a complete and utter doddle on new chassis's,then a quick go over with Waxoil/Dinitrol/Bilt Hamber.Remember once its oiled you'll never be able to paint it again with serious work to remove the old waxoil.
Certainly wouldn't be taking it back to a useless stealer to deal with. Pov.spec,ftw. 2006, 110,TD5.
Post #465751 23rd Oct 2015 11:12am
Retroanaconda
If an oil leak was an MOT failure most British cars would be off the road! They're not known for their oil retention. Obviously some leaks that are safety issues such as those compromising brake systems or those so great in volume that they would present a hazard to other vehicles would be failed.
Environmental protection isn't as high up the agenda here as it is in Europe. Until scrap prices rose the standard method for disposing of old machinery for example was to either park them up and forget them or dig a big hole and bury them. A few years ago I spent a few weeks with a JCB digging a dozen or so vehicles out of one of these pits to scrap them. The water in the hole was very rainbow coloured to say the least with all the oil.
Post #466018 23rd Oct 2015 11:20pm
Cuthbert
Retroanaconda's first sentence sums up the 'British' approach to the environment quite accurately.
Post #466166 24th Oct 2015 5:34pm
Page 2 of 3 <123>
