Page 855 of 1392 <123 ... 854855856 ... 139013911392>
Qanfud
Malta 2011 Defender 110 Puma 2.4 XS CSW Indus Silver
A picture says it better:)https://www.defender2.net/gallery/albums/userpics/19115/thumb_image.jpeg
Post #464122 17th Oct 2015 7:35pm
alexatnd
Well,
Removed starter motor and replaced brushes. Getting it back in was easy .... except for tightening up the nut at the top holding it onto the gearbox/engiine. May have got it out o.k., but socket extension bars I've got are either too short or too long to tighten it up.
Everythnig works, just don't want to drive around with the possibility of it falling off. Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road
Effie - 2004 110 TD5 County
Post #464126 17th Oct 2015 7:46pm
grumpy old git
You'll probably be OK without the infamous top bolt, the large majority of them on Td5 starters end up chucked over the hedge! My last D2 never had one on, no problems in close on 100K miles in my ownership. Most people use a 5" ish 3/8" extension and wrench if they bother from what I've read.
Post #464159 17th Oct 2015 8:51pm
g-mack
spent 2 hours off roading around the countryside in the pitch black searching for my young Labrador that bolted chasing a hare! found him on a roadside! Shocked one lucky pup! My 109 thread
my youtube channel
Post #464171 17th Oct 2015 9:23pm
alexatnd
That's good to know. O.K. I'll have anoher try at tightening it tomorrow and if that don't work I'll judt have to wait and see what happens
Thx
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #464183 17th Oct 2015 9:40pm
Shocked
Well done! One of ours did that once but never had the chance again.
In the mean time a nice extending lead might be in order. Wink
Post #464184 17th Oct 2015 9:41pm
Venomator
Friday Afternoon/Evening Actually...
Spent a wonderful good couple of hours stop starting around the M25 & Northwards on the M1... Thumbs Up
Driving my 110 Keswick Special for the first time as I trekked home... Mr. Green Mr. Green Mr. Green
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #464198 17th Oct 2015 10:28pm
Devon-Rover
I'll let the picture speak...
Post #464358 18th Oct 2015 4:30pm
excossack
Yesterday I was at the 60th year of the Cambrian rally. I was based at one of the Penmachno stages, on recovery duty.
Onto stage pulled a P38 2.5 followed by a cloud of steam from under the bonnet.
Turned out top hose had popped!
The owner soon got the hose cut down and refitted but needed water. In the back of the 110 was 5l tub of old tap water (certainly not drinkable) so that got donated towards the P38 and also 1 litre of Porsche antifreeze/coolant which had been in the back of the 110 for the last 5 years or so...just in case!
No recoveries to do on our stage, so we went into the previous stage to lend a hand, but only one left and that was a Micra nose down into a ditch. With a quick tug from another 110 the Micra was out. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #464369 18th Oct 2015 5:07pm
Fixed a mates turbo hose and had a good defender natter Thumbs Up
Post #464389 18th Oct 2015 5:47pm
excossack
Did a tip run.
Replaced the drivers side door switch.
Serviced the 110. New oil filters, air filter, fuel filter and new oil.
Cleaned the engine down to try to track down the oil leak(s).
Started off with a garden sprayer and some Roc degreaser and got the pressure up on the sprayer and proceeded to jet wash the engine starting at the top and then going to the bell housing and surrounding area.
Finished with the Roc degreaser and then added to the sprayer some washing up liquid and some boiling water. Again pressure up and sprayed the engine down.
Quite a lot of the gunk came off and then did another kettle full into the sprayer and gave it one last wash with hot water.
Engine now cleaner. Fingers crossed I can track the leaks. The two main areas I think are;
Rear half moon on rocker gasket (yet again) and front cam seal (yet again) 1999 Defender TD5 110
Regards
John M0VAZ
Post #464416 18th Oct 2015 6:51pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Took the dogs for a walk up the hills behind Newcastleton in the Scottish Borders. Obviously we got there by Landy, a cracking wander on a cracking day.
Post #464423 18th Oct 2015 7:19pm
Stacey007
Sorted my squeaky clutch pedal with Instructions on this site,
6 screws holding the clutch cover plate under bonnet, 3 in 1 oil and grease.
Squeak gone
Ace
Post #464426 18th Oct 2015 7:23pm
BigRuss
And I was the only one whistling on the way home! Russell
2011MY 110 XS USW Black
Post #464427 18th Oct 2015 7:25pm
Derrickthedefender
United Kingdom 2004 Defender 90 Td5 SW Zambezi Silver
Put my pride and joy up for sale Sad Big Cry A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!!
Yes the name for my 90 is Derrick!
Post #464451 18th Oct 2015 8:27pm
