Home > Maintenance & Modifications > DIY Front Bumper DRL it it easy to Drill ?
Stacey007
Hello
I like the Urban Truck DRL round gloss bumper for my truck, don't like the price.
Now a new bumper with caps I can get for £80 ish
these DRL's £25
http://www.ebay.co.uk/itm/181436361867?_tr...EBIDX%3AIT
and then a spray over in gloss....
Are these bumpers easy enough to drill? with these type bits?
http://www.ebay.co.uk/itm/16-60mm-9341-HSS...1810826965
It would be half the price easily? and I could have some spare lights in case they break / fail
Does this wound easy enough to do?
Post #463038 13th Oct 2015 9:40pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
I think you'll end up chipping the paint around the edges of the holes, then the chips will show through the paint. I'd use starret holecutters as theyre good quality, not the cheap ones you're looking at on ebay. Then, once the holes are cut and sharp edges sanded/filed smooth, sand the bumper down and paint all three faces again.
Post #463040 13th Oct 2015 9:45pm
JAY BOY
Wales
It would be all about the measuring and cutting the whole in the centre.
I would measure measure and measure again.
Use a centre punch before putting a drill anywhere near it.
Use lots of cutting paste and go really slow with the drill.
Deburr the hole.
Clean all the grease off with brake cleaner
paint and install your lights.
I bought one that was already done. Whistle
Post #463043 13th Oct 2015 9:49pm
dioliahary
I cut mine using a hole saw, it went OK had to file the internal edge down. I then put some edging trim on, it looks quite good, I will dig a picture out and post.
Post #463046 13th Oct 2015 9:52pm
Stacey007
^ thanks a picture would be good.
did you re-spray?
Post #463051 13th Oct 2015 9:58pm
dioliahary
Just touch up paint
Post #463143 14th Oct 2015 10:05am
dioliahary
Trying to post a picture
Post #463144 14th Oct 2015 10:06am
dioliahary
There you go finally
Post #463172 14th Oct 2015 11:08am
dioliahary
Post #463179 14th Oct 2015 11:18am
dioliahary
Was tricky making the light brackets though
Post #463180 14th Oct 2015 11:19am
K9F
The Premium Recess Model from UT does indeed appear quite costly at nearly £500. Shocked
The OEM bumpers are made out of not much more than Bacofoil. I would think that drilling such a large hole may compromise what little structural integrity it had in the first place? First Four are a company that provide good quality HD bumpers with and without DRLs at reasonable cost. Maybe worth a look perhaps? I bought one from them albeit without DRLs and it has stood the test of time extremely well. You could consider buying a HD one drilling it, having it repainted/recoated in the colour of your choice, fitting the lights and still save a packet against the above cost?
http://www.firstfour.co.uk/products/non-wi...ty-bumpers If you go through life with your head in the sand....all people will see is an ar5e!!
Post #463182 14th Oct 2015 11:21am
Vintagepaul
2015 Defender 90 Puma 2.2 HT Santorini Black
May be worth contacting LRI Solutions who are on this site.
They did me an Urban Truck Satin Quad DRL Bumper
for £310 including delivery which was about 20% less than Urban Truck themselves.
I'm not sure of their price on the twin DRL bumper but I would have thought the discount would be similar
www.lrisolutions.co.uk 2015 Defender 90XS HT
Post #463233 14th Oct 2015 3:01pm
Stacey007
Some good ideas
It sounds an awful lot when a bumper can be had for £80 ish that's all...
The lighting kit is not very expensive either. I guess your paying as its done...
But then I would still need it fitting or is it easy to wire in?
Thanks
Post #463235 14th Oct 2015 3:25pm
gilarion
Simple way to do it, get a local machine shop to drill the holes that is what I did and it cost me £20.00. Holes were perfectly round, no rough edges and accurate and no chipping round the edges. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #463237 14th Oct 2015 3:33pm
dioliahary
I took a fused feed off the alternator to the nc contact tips of a 12 volt relay whose coil was actived when side or full beam was requested
Post #463281 14th Oct 2015 6:44pm
