![]() | Home > Td5 > Rear auxiliary light switch for Defender |
Yug000540lnf is that the one you mean? Ray
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 365 ![]() ![]() ![]() |
I'm not sure if this switch will work. I have one installed for the spotlights but I want a switch to operate a rear work light. Preferably a switch that is independent, not connected to a other system as with the front spotlights, like the rear wiper switch.
I don't think Landrover did a dedicated switch to fit in the dash but I found a switch from Australia while searching the net a while back but can't find the link anymore
![]() My build thread http://www.defender2.net/forum/topic17615.html |
Thanks.
If the rear wiper switch can do the job I can just replace the button with a blank one. But I still need the part number and a general hint of the wiring. |
Found it
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6681 ![]() ![]() ![]() |
I believe the cheapest "latching" switch is the Puma heated seat one: YUF500150LNF
Wiring here: http://www.defender2.net/forum/topic40819.html ![]() ![]() |
It might be worth pm'ing paulmc as he's very good at this and can also supply the parts. Ray
So I'm no good?
Thank you for your help. I can now start planning .
Can you help me with the wiring diagram of the YUF500150LNF switch.
In the thread I posted a link to above is a pinout of the Puma heated seat switch
![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
Thanks again.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17850 ![]() ![]() ![]() |
Does anyone know if these switches are available in the UK, or if Expedition Centre will ship to the UK for a reasonable sum? Or, for that matter, if just the fascias are available in the UK? Thanks. |
