Home > In Car Electronics > Using a heated seat switch for reverse camera....
mcma1
I have a spare heated seat switch which I have a new head attached to from a discovery just to have a different symbol.. Anyway I want this switch to trigger the reverse camera, anyone suggest what way I need to wire the switch.??
Thanks Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #462979 13th Oct 2015 7:24pm
Martin
Site Admin
Puma heated seat switch?
If so:
1 12V in
2 illumination 12V
3 not connected
4 12V out
5 ground  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #462989 13th Oct 2015 7:55pm
mcma1
Thanks Martin,
Yes Puma switch....
What could i use for 1 and 2?? Can i just tap into the wires to a heated seat switch? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #463001 13th Oct 2015 8:19pm
Martin
Site Admin
Yes if the current draw you are taking is small Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #463005 13th Oct 2015 8:25pm
mcma1
Understand, so really I would be better to take the 12v in from the battery? Rest ok from the other switch? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #463011 13th Oct 2015 8:33pm
Martin
Site Admin
What is it powering? You say a reverse camera so presumably you can find out the current draw?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #463041 13th Oct 2015 9:45pm
kmac
For a reverse camera, the cigarette lighter is also an option - it has a 20A fuse I believe
Post #463054 13th Oct 2015 10:00pm
mcma1
Yup, will look it up when it arrives tomorrow, just an Alpine rear camera that I want to be able to fire up with reverse or the switch... Andy
2014 Corris 110 SW
LS3 V8 build...
Post #463055 13th Oct 2015 10:00pm
Martin
Site Admin
Heated seats are 20A too.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #463056 13th Oct 2015 10:06pm
Dave Bellis
United Kingdom 2014 Defender 90 Puma 2.2 HT Keswick Green
What is the maximum current that a seat heat switch YUF500150LNF contacts can carry?
Post #463067 13th Oct 2015 10:41pm
Martin
Site Admin
The pair of seats are fused at 20A, so I wouldn't be putting more than 5A through one of these switches.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #463119 14th Oct 2015 9:02am
Dave Bellis
Slight side issue, I was thinking of switching about 2 amps through one of these switches just wondered about the contact current rating?
Post #463125 14th Oct 2015 9:16am
Martin
Site Admin
Last time I checked, 2 is less than 5 Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #463129 14th Oct 2015 9:23am
Rolling with laughter no Censored
Post #463140 14th Oct 2015 9:56am
mcma1
the power consumption is rated <2.5 watts so think i should be ok... Smile Andy
2014 Corris 110 SW
LS3 V8 build...
Post #463169 14th Oct 2015 10:59am
