Home > Td5 > transfer box bearing
hily
United Kingdom 2005 Defender 90 Td5 PU Belize Green
I have replaced transfer output shaft bearing approx 10,000 mile ago but think it has started to cause a vibration again anyone know if I can replace this bearing with a higher spec one.
Post #462874 13th Oct 2015 1:03pm
Martin
Site Admin
Genuine/OEM or pattern bearing?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #462879 13th Oct 2015 1:20pm
hily
skf from bearing services
gone for skf 6207 c3
Post #462909 13th Oct 2015 2:41pm
ashtrans
Site Sponsor
Hi,
Are you sure the one that came out was a C3 ?
Dave Dave
Post #463104 14th Oct 2015 7:00am
hily
no the one that came out was a skf 6207 expedition the one I am going to replace it with is a c3 as this has more radial play so hopefully have less load and a longer life .(or so Iv'e been told)
Post #463132 14th Oct 2015 9:32am
kevinf
hi there
sorry about hi jacking this topic but I have been chasing a vibration on my td5 110 since I had the gearbox repaired and the internals of a disco 1-1.22 transfer box fitted to my original transfer box at the same time I fitted a x brake which seems to amplify the vibration in to a knocking noise, I would be interested in knowing what your symptoms are i.e when the vibration is noticeable
cheers kevin
Post #463152 14th Oct 2015 10:21am
hily
first sorry for late reply .OK after getting stuck and rocking the defender out I had what seamed to be a prop u.j.vibrating any way after a long search it was a bent output shaft NOT LIKE A BANANA BUT RUNNING OUT WHEN MEASURED ON A LATH and rough bearing .so replaced the shaft and to be honest put a cheap bearing in .the bearing had to be replaced after approx. 5000 mls so replaced with a SKF bearing this has lasted longer now I suspect I have a fault in the transfer box that is putting pressure on the output shaft bearing so have decided to try a bearing with a little more radial clearance (play) than the original spec don't want to strip transfer box as it works fine at the moment. The symptoms are rough vibration at 40-45 when accelerating hard or slight vibration when driven as I normally do like an old lady Embarassed .
Hope this has helped with diagnosis .
Post #463409 15th Oct 2015 10:06am
kevinf
hi hilly
thanks for the reply my vibration was initially apparent when accelerating, but now is noticeable at idle even when out off gear so deep down I suspect its the dmf but I'm still hope I can find something less painfull to repair
cheers kevin
Post #463973 17th Oct 2015 9:22am
mk1collector
Check the crank pulley as these can cause a bad vibration. Does the engine make a chirp noise when you switch the ignition off? Ray
My build thread
Post #464002 17th Oct 2015 10:41am
kevinf
hi ray
thanks for the input I had heard that crank pulleys were prone to fail , there is no obvious signs of failure on mine but there is a definite vibration on the engine which cause the engine top cover to rattle, but I don't think it would be noticeable if I hadn't fitted the x brake ! think I'll have to let it develop !
cheers kevin
Post #464580 19th Oct 2015 10:22am
