Home > Technical > Limited travel on wipers
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
Hi All,
SWMBO's '98 300tdi has developed a problem with the wipers, the swept arc seems to have decreased by about 4 inches so that when they park/finish the downward swing they stop well up the windscreen, but they are sweeping up to their correct position. With the wipers off and "parked" they can be pushed down to their correct park position. I have tried repositioning them on the spindles but this leaves a large unswept area in the top right of the screen.
Before I dismantle the whole of the dashboard can anybody suggest an easier fix, or what should I be looking for if I have to get the dash off?
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #462852 13th Oct 2015 11:49am
This will be caused by wear in the drive linkage, it could be the drive gear/crank pin, the rack/wheelboxes, or most likely the cumulative effect of wear in all these places.
It isn't expensive to overhaul the motor gearbox and crank, and replace the rack and wheelboxes, and the wiper performance will be transformed.
Post #462858 13th Oct 2015 12:14pm
ChrisCM
Thanks for the reply Blackwolf. This what I suspect as well! Just hoping that there was an easy fix, not requiring a strip of the dashboard 😕
Post #462878 13th Oct 2015 1:20pm
Martin
Site Admin
If it has the pre-Td5 wiper boxes, check the spindle adapters are tight on the wiper shaft which sticks out of the bulkhead.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #462899 13th Oct 2015 2:16pm
Grenadier
Re: Limited travel on wipers
ChrisCM wrote:
Hi All,
Chris
I think you should count yourself lucky that they move at all... Whistle Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #462922 13th Oct 2015 4:32pm
ChrisCM
Thanks Martin, Spindle adapters are tight.
Grenadier, Let's hope they still move after my attempts at an overhaul Laughing
Post #464060 17th Oct 2015 3:15pm
