![]() | Home > Technical > Limited travel on wipers |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17871 ![]() ![]() ![]() |
This will be caused by wear in the drive linkage, it could be the drive gear/crank pin, the rack/wheelboxes, or most likely the cumulative effect of wear in all these places.
It isn't expensive to overhaul the motor gearbox and crank, and replace the rack and wheelboxes, and the wiper performance will be transformed. |
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 ![]() ![]() ![]() |
Thanks for the reply Blackwolf. This what I suspect as well! Just hoping that there was an easy fix, not requiring a strip of the dashboard 😕
Chris 2010 Defender 110 Station Wagon, Santorini Black. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6682 ![]() ![]() ![]() |
If it has the pre-Td5 wiper boxes, check the spindle adapters are tight on the wiper shaft which sticks out of the bulkhead.
I think you should count yourself lucky that they move at all... ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Thanks Martin, Spindle adapters are tight.
Grenadier, Let's hope they still move after my attempts at an overhaul ![]() Chris 2010 Defender 110 Station Wagon, Santorini Black. |
