Home > Technical > Error message on odometer
N16kct
United Kingdom 2010 Defender 110 Puma 2.4 USW Corris Grey
I have had an issue with my 2.4tdci recently.
A few weeks ago I jumped in, went to start it and the gong for low fuel sounded. Started fine but my fuel and temp gauges didn't move the entire journey.
Next time I stated it, it was fine. Next morning, same thing but a error message was displayed where thw mileage should be and the speedo was reading 86mph and therefore limited however it was only doing 72mph @2300rpm (or there abouts)
I noticed the earth clamp on the battery was loose, so had this replaced. No change.
I'm not really sure where to go next. The car is audibly rattly at various rpm sometimes it's there sometimes it's not, but it seems more rattly when I get thw error message.
Usually I get around 265miles to a tank running esso premium on a motorway run with MT's fitted.
Oddly enough, it was fine up until I changed the shocks, but I can't see how that's caused any issues.
Any ideas?
Post #462678 12th Oct 2015 8:08pm
Make sure the earth clamp is tight again.
But first disconnect the battery completely for a few hours.
Post #462681 12th Oct 2015 8:18pm
N16kct
Thanks for your reply, I have tightened the new clamp and it's all good. I've not left it off, but I'll trythat tomorrow. Sometimes I get in and it's completely fine so I can't quite get my head around it Embarassed
Post #462682 12th Oct 2015 8:22pm
N16kct
I took it to the local specialist this morning. A number of fault codes came up and most of them state lack of signal from various devices. They tried to clear the codes but they kept coming back.
They've suggested it could be wiring, the clocks or the ecu.
Crying or Very sad
Post #463151 14th Oct 2015 10:20am
K9F
This is the vehicle you're selling is it not with the intention of doing a 3.2 build???
Regardless I would drop Lorryman100 a 'pm' together with the codes you had and see if he would be kind enough to shed a little light on the issue? He has helped many out before! Also invest in a decent code reader, it will be invaluable with this problem and your intended project.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #463170 14th Oct 2015 11:04am
N16kct
Basically, I was in two minds at the start, wether to do the 3.2 in this or a 110 utility, thw later being more practical for me. But as time has gone on, I'm pretty set on keeping this as I can't find a 110 in budget in the same condition.
Thanks for the pointer though I'll give him a try Thumbs Up
Post #463192 14th Oct 2015 12:28pm
Martin
Site Admin
Post up the list of error codes here so we can all have a look?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #463208 14th Oct 2015 1:33pm
