Home > Maintenance & Modifications > A weekend well spent?
mse
I've spent most of yesterday and half of today waxoyling the 110 Very Happy
A small amount of doubt spread has spread in today, I have to say mainly from this forum Shocked , regarding using waxoyl especially with the dinitrol supporters. In fairness the 90, puma 90 and 300tdi discovery all had waxoyl after 3 years the 90s were fine and after 16 the discovery is ok, so I'm trying to convince myself I've made it better not worse!!
Why waxoyl...I had some, both waxoyl and underbody seal, I could get the rest in time for this weekend (and the only chance to do it was this weekend), it's been fine in the past.
I ran out so have some dinitrol coming for the last few bits
It's gone on a 99% clean, new chassis and floor., bone dry with only delivery miles..about 8.5l waxoyl and 5 underbody seal...just the top of the bulkhead of the bulkhead (not the courners the were sprayed)and doors to do. But we can use it now it's protected
Oh and before applying I stone chip guarded the arches and front out riggers and a few other high impact areas
Let's hope I made it better for the future Exclamation Question Mike
Post #462446 12th Oct 2015 12:44am
Mo Murphy
Beware the Dinitrol police are watching ...
50 Shades of Pennine Grey
Post #462450 12th Oct 2015 4:14am
mse
It will either work or not Rolling with laughter Mike
Post #462582 12th Oct 2015 3:59pm
X4SKP
Hello mse
I have used both:
Waxoyl 1275 GT Mini / TVR Taimar / 300tdi Defender SWB
Dinitrol 2.4tdci Defender 90
My observations would be:
1. Both are good.
2. Quality of Preparation and Application will determine their success.
3. I would not 'mix' the Products, generally as this stuff sticks to itself best.
4. Dinitrol was easy to work with, but the difference overall is probably marginal.
5. Appearance of Black Dinitrol (4941) is really good when applied.
6. If I do this again (on a new vehicle) currently it will be Dinitrol.
7. When the 90 gets more, it will be Dinitrol.
Waxoyl Vs Dinitrol analogy PC Vs Mac...your either one side or the other,
but both are very capable.
There are some super tough plastic / synthetic coatings out there that are generally out of reach
of a DIYer or even Specialist Independent both by price and the methods of application needed to
apply them correctly.
With a move towards Aluminium and Composites for vehicle manufacture (even rumored for the replacement
Defender) what we are doing for Steel is a necessary step to preserve it but one that may well be designed
out...eventually. Thumbs Up SKIP
Post #462618 12th Oct 2015 5:45pm
K9F
X4SKP I had my Defender originally done with Waxoyl since then I have topped up and treated where necessary with Dinitrol. Both are very good products in their own right and I agree wholeheartedly with your reasoning and points above. Waxoyl can be a messy affair and a ba5t4rd to work with in lower temperatures unless you can pinch a baking tray from SWMBO to stick some Waxoyl in to warm in the oven or have a wood burner on which you can warm the stuff on in the tin. Dependent on outside temperature your window of opportunity to get the stuff applied before it turns to chewing gum can be small indeed.
Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #462622 12th Oct 2015 5:57pm
mse
Thanks Guys - its reassured me Thumbs Up
I leave it in the airing cupboard to warm...always works well, except it was a pig when starting to cool on Saturday (not a warm day)
Going drinitol for the last few bits purely because ive run out of all waxoyl now and the drinitol aerosol seems like it might be easier to get in the top of the bulkhead and doors without getting out the compressor cleaning etc
Im never too bothered about appearance underneath although it looks fine - probably a brand new chassis helped with that one.
Just the axles left underneath to do Mike
Post #462627 12th Oct 2015 6:14pm
