Home > Maintenance & Modifications > Rusty 14reg
RobKeay
Rusty 14reg
I have a 14 reg 110 with a rusty window. First one I've had go like this but I know others have had the same problem.
Do I leave it to next service or get it sorted now.
Post #462497 12th Oct 2015 9:43am
K9F
Raise it with your dealer and he can get photos himself and get the necessary approval in advance. It'll be a windscreen out job and I would request they use sealant to seal it back in to prevent the ingress of crud in the windscreen seal that retains moisture and causes the issue. (I had exactly the same). The window blocks are also notorious for this and I eventually just swapped mine out for either Croytech or stainless.
Up to you if you have it done at a service? My dealer has it's own body-shop but it is situated elsewhere and has it's own reception and booking in process so you may have to align the servicing and repair accordingly with the two?
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #462499 12th Oct 2015 9:52am
steve E
Wales
Hi Rob
I would have it done sooner rather than later.
It's an easy fix and one that your dealer has seen a million times.
Don't wait and let it get worse Thumbs Up
Post #462500 12th Oct 2015 9:52am
RobKeay
Cheers I'll get it down to the dealer later. Bit disappointed as this one has done 40k trouble free miles.
Does the paint have to fall off before they sort it out or will they sort the bubbling. Do want it sorting as we can't get a new one.
Post #462503 12th Oct 2015 9:59am
RobKeay
I was thinking about swapping the blocks they didn't bother me. I was looking into updated bonnet hinges.
Post #462504 12th Oct 2015 10:01am
K9F
They'll sort the lot out! Thumbs Up
Rob whilst you're at it I would go over the rest with a fine tooth-comb and see what else you may discover especially rear cappings, roof gutters, lower rear edge of front bumper, lamp bezels, sidesteps (if fitted) and intercooler grille to name but a few? Just a selection of the 'usual suspects' along with the two mentioned in your post. You could get the lot done in one go, whatever you find.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #462505 12th Oct 2015 10:19am
nitram17
Re: Rusty 14reg
Isnt the frame alloy! alloy corrosion after a year is disgraceful! needs sorting straight away!
Post #462511 12th Oct 2015 10:50am
K9F
The collection of dirt in the window frame under the seal is very common and very well documented. It shocked me when I saw on mine how much had accumulated. This then retains moisture and it rots out very quickly. Below is a cut and paste from another thread and details in the link contained therein of how the same issue was causing damp footwells.
"Details of leaking seals and crud collecting underneath are well documented......only real way of sorting is get the windscreen out, channel cleaned, new seal and sealant applied on refitting the glass. Otherwise you'll simply be sealing the crud in that's already there."
K9F wrote:
Autoglass...You have no worries whatsoever, also get the seal off and the area thoroughly cleaned. I had two replaced in short succession by Autoglass and it is an ideal time to get the crud cleaned out under the seal and get it sealed correctly.
My advice would be to be in attendance and read carefully the issue of dirt ingress in the thread below, especially my posts and Fekete's on pages 1 and 2....
http://www.defender2.net/forum/topic2126.html
As for the false hinges they too rot out and can let water in. I bought some stainless replacements from OX4X4 and made butyl gaskets.
Post #462516 12th Oct 2015 10:58am
m33ufo
Wales
No expert on these things...but if it is alloy then it's probably more susceptible to corrosion due to contamination from ferrous metals.
Post #462517 12th Oct 2015 11:01am
nitram17
Your right but i thought the process was a little slower than rust......corroding after a year is disgraceful!
Post #462519 12th Oct 2015 11:26am
m33ufo
Wales
I think the idea is that the process should be free from contamination in which case you won't have a problem. I had a similar issue with an XKR quite a few years ago.
And I agree, it's shameful.
Post #462521 12th Oct 2015 11:34am
RobKeay
I have already had to replace the windscreen. The metal round the window was holding a lot of water. The chap from auto glass put some black sealer on it.
I will go over the rest of the 110 ASAP probably join the detailing club on here and have a go with a clay bar. I'll be booking it in for under body protection after I sort the window as well. The rear cross member has lost its colour.
Cheers for the replies
Post #462544 12th Oct 2015 12:58pm
nitram17
steve E wrote:
Hi Rob
What do you mean by easy fix? quick rub down and paint or windscreen out frame out rub down and paint and re seal?
Post #462562 12th Oct 2015 2:53pm
steve E
Wales
I meant easy for an expert body shop to repair.
and easy as they repair these issues all the time,
and easy as in don't loose any sleep over it, as it will be properly fixed.
Post #462597 12th Oct 2015 4:48pm
K9F
The only difficult aspect as explained to me by the experts is getting a heated windscreen out (if you have one fitted) without damaging it. The elements are inherently liable to damage on removal and that is why when you are suffering with water ingress this is the last thing they will do before all other avenues are explored first. If you've not a heated windscreen no worries whatsoever.
Post #462601 12th Oct 2015 4:57pm
