Home > Td5 > non starter help needed urgently
razorruddock
Hiya people need your help I have a defender 90 td5 stripped it all had chassis galvanised etc. When I rebuilt it I lost me ecu earth so I put I direct earth to the ecu from the negative on the battery that solved the problem but ever since I stripped it the stupid thing I was having trouble getting it started. I was having to use easy start to make it fire up this worked ok for a while but now it won't start at all. Just turns over I've noticed the fuel pump in the tank is staying on for a while and it's not shutting off. And also when I try connect to the ecu it's saying connection error on the diagnostic machine but the ecu light is showing on my dash when I turn ignition on. Need serious help anything is really appreciated
Post #462386 11th Oct 2015 9:22pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I had a ecu light when one of my keys went chips. The spare starts it fine but the bad key just brings on the ecu light and wont start.
do you have a spare key/blipper? 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #462398 11th Oct 2015 10:00pm
razorruddock
My defender doesn't have a chip in key pal it's 52 plate bog standard it doesn't have central locking or anything like that
Post #462522 12th Oct 2015 11:37am
Martin
Site Admin
Which light is coming on on the dash? There are many...  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #462531 12th Oct 2015 11:58am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
Sounds to me like the immobiliser may be causing the problem, loss of power can cause the 10AS to lose sync with the engine ECU.
Post #462548 12th Oct 2015 1:20pm
