Home > Maintenance & Modifications > To swap door bolts do you ...
RRUK
have to remove door cards to swap out the hinge bolts on the front and safari rear door?
I am changing mine to Stainless gradually... 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #460631 5th Oct 2015 2:15pm
On the side doors (front and rear) you can get a spanner on the nuts without removing the door card. You may have to ease the card gently away from the door, but there's no need to remove it. I'm not sure about the rear 'safari' door because I have a tailgate!
Post #460641 5th Oct 2015 2:27pm
Martin
Site Admin
It is possible to do without removing the door cards, the thinner a 13mm spanner you can use the better.
Worth protecting the door frame against scratches/marks from the spanner head, slide a bit of cardboard or similar into the gap.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #460643 5th Oct 2015 2:30pm
X4SKP
Hello RRUK
I have what you have, well more or less 2.4, 90, MY2011
and blackwolf is right.
I have also just completed exactly what you are doing changing over all to SS.
Rear Door a combination of completely visible and therefore self evident swaps
and the requirement to remove interior panels, lower hinge is from below cross member.
Side Doors bolts into bulkhead all have captive 'nuts' so just remove and replace
one by one, those through the doors, with the nuts just visible on the edges of the door cards
can be accessed by pulling back the door card (very slightly) right along the forward edge and
lower front corner the plastic 'christmas tree' like fixings will releases quite easily. I used a ring
spanner, with a slightly angled head to get on these internal nuts.
Tip 1 for those bolts where you are required to get on the inner nut, you may find it easier to
tighten the whole thing up by keeping the Torx head (and therefore bolt) stationary and tightening
the nut only, this lowers the chance of deforming the Torx head if everything is not ideally aligned.
Tip 2 it took me a few minutes longer than it should to work out that the whole job of
tackling the upper door hinge , door side bolts (not bulk head side), would be much easier
with the electric windows lowered... Embarassed you can then get on both sides of this bolt then easily.
Tip 3 obvious... but do the bolts one at a time, to prevent any misalignment / door dropping
check once, check twice and check again especially if you then implement the 'ball bearing' security
measure.
Tip 4 again obvious also but if you plan to Dinitrol either inside the cavity of the rear door frame
or the front bulk-head, get this job done first if you want to then 'secure' the bolts by any method.
Good Luck SKIP
Post #460664 5th Oct 2015 3:14pm
Roy5695
I'd also look into applying some form of barrier paste to the stainless bolts so they don't start to react with aluminium if salt water gets between them.
Look at galvanic corrosion on a search engine and you'll see why I suggest this.
Post #460670 5th Oct 2015 3:40pm
leeds
The Nakatanenga bolt kits we supply come with paste as standard and have the genuine shaped door bolt heads.
Another tip.
When replacing the B pillar door bolts and using paste keep the seat belt webbing away from the bolt as you tighten it up and wipe any excess paste off the bolt so it does not transfer itself to the seat belt webbing.
Brendan
Post #460680 5th Oct 2015 4:18pm
1978
United Kingdom 2003 Defender 90 Td5 HT Belize Green
Is the Nakatanenga kit supposed to come with a diagram to show where all of the bolts should go? I've worked most of mine out but still have a good few left over!!
Post #460692 5th Oct 2015 5:05pm
Another tip: if, like me, you have stuck ball-bearings in the heads of your screws, allow around an hour per screw to remove them. It really is extraordinarily difficult!
It's reassuring really, but it is a pain to do.
Post #460725 5th Oct 2015 6:56pm
K9F
I swapped out all of the exterior bolt on bits 'n' bobs over time for stainless over a prolonged period of time including the windscreen blocks and bonnet hinges. All points have been covered quite comprehensively, the most difficult out of the lot as mentioned has to be the lower rear Safari door hinge which involves getting underneath, ideally a second pair of hands is the ideal scenario for that one hinge.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #460737 5th Oct 2015 7:26pm
Screbble
Hey K9F,
Those s/s hinges are a work of art - things of real beauty. Thumbs Up
I am Mr. Green with envy.
They are so highly polished that they look chrome.
They are on my list!
Sorry for hijacking the thread a little. Whistle
I agree with retaining the Torx head. I chose an Allen head s/s replacement and poor quality at that. They look ok but wouldn't be my choice again.
Barrier paste 1000%
Post #460776 5th Oct 2015 8:34pm
K9F
Thanks Screbble,
Not cheap and had to wait several months after registering my interest to get the hinges as the first batch took ages to get polished.
http://www.yrm-metal-solutions.co.uk/YRM-L...oor-Hinges
Window blocks I originally had Croytec ones but subsequently swapped them out for stainless ones too. Bonnet hinges came from OX4X4 firm based in Guernsey but also available from YRM above. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #460781 5th Oct 2015 8:54pm
Screbble
Thanks for the link K9F. Really high quality products. Thumbs Up
Father Christmas will no doubt be starting to compile his list shortly....... Laughing
Post #461033 6th Oct 2015 7:23pm
leeds
Sorry no diagram to show where all the bolts going. There are basically two complete kits to cover a wide range of Defender. Hence there may well be surplus bolts, just put them in your spare bolt box.
Brendan
Post #461053 6th Oct 2015 8:13pm
ericvv
Re: To swap door bolts do you ...
No, you don't. I recently replaced all my door bolts again, and on some doors you just have to carefully pull loose one door clip or so with a bit of force. Must admit I damaged a single lower 2nd row door clip in the process, but I have that replaced by my dealer. Simple.
As to the choice of anti seizure paste for your new bolts, suggest you look up a thread I started on the subject simply by putting "Weicon paste" in the search engine. The info is in the 1st of 2 threads started by myself. Then make up your own mind about what you think will be better.
Good luck. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #461169 7th Oct 2015 6:33am
