Home > Maintenance & Modifications > Fuel Leak... Have you seen this before?
Page 2 of 3 <123>
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
I get a very similar amount out of mine if the tank is full. i first noticed it after some mild offroading where the fuel must have been sloshing about and getting right up to the neck.
I've found if I fill to the first click it doesn't do it, hopefully yours is the same Very Happy
Post #334775 31st May 2014 1:17pm
munch90
I changed my hose last week , found also tank wont move enough to drop down
so fitted new pipe without moving tank
I cut a small round hole inside on the floor so could get to do up new clip easy , then fitted a bung in the floor in the hole ( rear is carpeted so bung is under carpet )
makes it a 5 min job to replace pipe in the future
whole job took about 25mins and £10 for enough pipe to do it twice
only thing was pipe was like new when it came off but fitted new length anyway
Post #334781 31st May 2014 1:54pm
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
Maxx Ross, my symptoms are exactly the same as yours
Post #334802 31st May 2014 3:39pm
X4SKP
ronwong wrote:
Excellent write up, I have the leak for some time and no it's not 3 years, my puma 2.2 is only 1.5 years old. If I fill to the brim, about 200ml will leak onto the floor and I can see the top of the tank is wet, so I think this is the same problem I am having.
I just want to check, you have this pipe that comes out of the tank that is short, and connects to the t junction which has a J hook on it and follow by a long pipe. The J part is the breather right? And it does not leak? The leak is on the short piece? Where does the other long end connects to? Is this pipe where the fuel goes to the engine or there are other fuel lines? Sorry I have not got the time to look under yet.
Hello ronwong
Welcome to the culb Exclamation
To answer your questions...
1. The 'J'' part of the breather pipe assembly does vent 'to air', and therefore is not connected to anything
its orientation is as shown, on the OS, side of the tank.
2. The 'J' part did not leak and appears to not be the vulnerable part here. I did reuse it.
3. The short piece of pipe (3/4 inch ID) had 2 splits on it and the larger piece had 1 split at the junction to
to 'J' smaller hose. At the other end of this larger pipe (at the fuel filler end) it was very cracked, but I had 1
right through split (small length of 3/4 pipe) and 2 well on the way to being right through.
4. The other end of longer 3/4" pipe (breather assembly) connects to the molding incorporating the filler cap
+ main filler pipe.
5. There are 2 additional main fuel lines that connect to the top of the tank together with an electrical connection for the fuel gauge, these are 'pinch' release / push 'click' to re-connect.
If Defenders ran on Petrol...this top leaking of fuel at the tank approximately 0.5M from the exhaust pipe
could (would) be much more serious... Evil or Very Mad ... I would suggest a fix and 3/4 fill tank until sorted.
Whilst my 90 is 3 years old, it had just 7k miles on it when the leak started, and had been off the road for almost 1 year of its life before I bought it, it has also been garaged, and has never 'live near the coast', a suggestion from LR as to why it may have failed so early... hardly helping the vehicles credentials Exclamation
Good luck with your fix. SKIP
Post #334828 31st May 2014 6:30pm
Chris-G
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
Hi X4SKP,
I just hit the same problem trying to remove the fuel tank on my 2013 D90. It just does not want to move forward more than a few mm.
My wish to remove the tank was triggered by another of your posts in the Corrosion treatment section ... removing the tank before Dintrol'ing. I wanted to do this too.
As a result of struggling to remove the tank and only finding your write up of one way of doing it today I have finished my Dinitrol treatment reluctantly with the tank in place .... as an engineer I'm not totally happy about that.
I will ponder your solution and may embark on something similar another time.
Anyway, thank you fro two excellent series of posts.
Regards
Chris 2013 D90 XS SW
Post #458954 29th Sep 2015 1:19pm
X4SKP
Hello Chris-G
I laid under my 90 and thought there just has to be away to get the tank out easier than the route I ended up taking, but the more I looked, and measured, pushed and pulled, the more 'attractive' my solution appeared.
I'm an engineer too, and whilst I was happy enough to tackle this, I genuinely don't know how Land Rover would remove the Tank on a 90 (I believe the 110 has better clearance).
I use the advice (and better pricing policy than LR) of a local Independent LR Specialist from time to time, and they said too that these can be a Censored to remove, there is also variation between inherently the same vehicles. They 'flex' the tank out with a length of scaffolding flattened at one end, they even have a name for it 'the persuader'.
Not really a good thing to do on a blow molded product, but it does pop it out if you try hard enough. If you then imagine trying the reverse the procedure, you will see that there is no easy purchase point for the operation, together with factoring in, supporting the tank without unduly stressing any of the connection hoses. Not a designed for maintenance set up overall... Shocked
I was forced to get the Tank Out, to replace the breather pipe, but the 'fix' proved useful when exposing (in my view) a key area for applying Dinitrol.
If you do get the Tank Out then clearly you are free to cover everything, and get in everywhere.
Currently (Tank In) whilst the underside of the rear floor is probably less important to treat, the forward facing rear cross member really can't be tackled (from this side) there are also some really good entry points to get internally, some possible from other directions, but you just wanted to have a clear view of attack for this treatment in this area.
Another advantage of Tank Out is that you can tape off the connection / release mechanisms for the fuel hoses so that if (when) you need to get to them later on, they are not clogged with Dinitrol
Good luck with perusing this
Tank Out view (90) with the modified Chassis Brackets to retain the Tank
Rear Cross Member SKIP
Post #458967 29th Sep 2015 2:12pm
Chris-G
Hi,
As you say the 'Persuader' approach is a bit offensive and still leaves you with the install problem.
You were very brave in making things maintainable for 'the next time' or the 'next person' ... always good if you can.
I do like the two views with the rear cross member and floor with the tank removed. But the car has got to be back on the road so I'm putting it back together now.
I will have a look at removing the under tray lugs and getting some suitable extension plates drawn up for another attempt at that area another time.
I am not proud of failing to treat that area. Embarassed
I will just have to live with the shame!
Thanks for some great posts.
Post #458976 29th Sep 2015 2:49pm
X4SKP
Hello Chris... I feel your pain... Exclamation
Would be good to hear if anyone else has experienced this or sees it differently. SKIP
Post #458986 29th Sep 2015 3:32pm
newhue
Australia
X4SKP, a 130 tanks drops out with little encouragement. It does't seem to be wedged in there like a 90 or rub on anything. The bash tray collects lots of dirt or sand however.
I added a drain plug to mine when I was washing it out due to contamination, and didn't want to do the job twice. I did reuse the rubber seal for the pick up (big hole on top of tank) but the dam thing leaked. A new seal, another $70 and the job done twice sorted it.
Well before the contamination, I have also had the breather on the J pipe somehow become clogged. The dealer tells me its common after water crossings apparently and fitted the situation. This caused the tank to pressurise and leak from ?. The dealer fixed it but looked like the lower port on the filler tube. So upon return I ran a new J bit of pipe up high into an external cavity of the body work to keep it clear of dust and water instead of leaving it right next to the rear wheel.
However when I had the tank out I noticed the J valve seems to have no flow either way, or has a pop off pressure to it that isn't obvious. Did you happen to check yours?
Now it's getting warmer leaks are becoming obvious. It seems I have a small pressure leak in the moulded plastic of the filler neck just under the cap. I tried welding it with the soldering iron but seems to have failed. But I'm also wondering if this leak/pressure could be linked to this J valve seemingly to have direction, or is it clogged again. I also need to do my hoses, they are cracked bit not leaking, so out it comes for a third time. Thought I'd buy a Toyota diesel breather as the Land Rover one is priced like their hoses, and perhaps last as long.
We have a little roll your eyes saying down here that it takes three attempts to fix a Defender. Have no idea where it came from but I seem to be going beyond, going further, going more than I should. Bloody Land Rover. My Defender and travels
Post #459364 30th Sep 2015 8:23pm
X4SKP
Hello newhue
Sounds like your chasing one or more problems...as you say Censored Land Rover.
To be fair i'd still rather get my toolbox out on a Land Rover as most vehicles now
appear to have gone totally down the route of 'look don't touch'!
Couple of Points
The valve in the small J pipe, is I believe a non return value, as if you blow down the pipe
both ways it works one way and not the other. This is (again I believe) to stop the fuel
leaking out in the event of a roll over, (being up side down), others on here may know more.
Raising this to prevent clogging if wading in or out of water with a high mud / sand content
should help and I have heard of others doing this.
Replacing the breathe pipe, at Land Rover prices I just decided I didn't want to do, I just couldn't justify
why it was so expensive. Beyond the price it was mainly to avoid the time and effort (apparently) required
every 2-3 years again I decided just wasn't on.
I'm fairly convinced that the marine grade breath pipe I used will last longer and at a fraction of the price,
its now being tested!
The tight geometry on a 90 rear tank getting in and out was an issue, it looks to me that the tank went in the chassis (at rolling chassis stage during manufacture) before the body went on, may be wrong here and again
some else may know, but this clip looks to support this view.
If your Tank leaks then it may possible to fix it, I did this on a Motocross bike once with success,
lots of youtube videos on this idea, but sounds like you have tried this.
Good Luck SKIP
Post #459499 1st Oct 2015 10:54am
newhue
Australia
Copied from another thread, words by blackwolf commenting on a leaking fuel tank pipes and a swooth sound when opening the filler cap.
In the event that this breather becomes blocked, there is a two-way safety valve incorporated into the filler cap which will open if the tank's internal pressure differs by more than a few psi from the outside pressure. The purpose of this is to prevent the tank from collapsing or bursting if the breather is blocked.
From your description your atmospheric breather (small pipe) is blocked so the tank is running in a depressurised condition, the pressure difference being limited by the safety valve in the cap.
This is bad for two reasons. Firstly the LP fuel pump will be working harder to draw the fuel to the engine, and secondly any dirt, wetness, and other grot can be drawn through the lock barrel in the cap into the tank.
My recent fuel problems (as reported in other threads) have made me hyper-aware of the vulnerabilities of the system. I would strongly recommend fixing this ASAP, and also extending the small breather pipe to somewhere you can guarantee is clean and dry, eg inside the rear tub.
Yep your right X4SKP seems I might have a few problems and perhaps making another. I was convinced I saw air bubbles coming from a seam in the mounded plastic on the filler neck just under where the cap screws on, perhaps I should get my eyes checked.. Definitely changing that valve for non LR one, mine is only 3 years old and been tucked away after the initial blockage <2 years from new. Have to admit you don't see many Defenders with a few years age on them that don't have a stain around the filler neck. My Defender and travels
Post #459633 1st Oct 2015 7:18pm
Natlas
Just found a picture of 2015 manufacture showing a new route for the small curved part of the breather pipe. May be of interest to those who are replacing their breather pipes. See post by CDN38 for link to many other manufacturing pics.
 2.2 90 XS
88" Series One
Old Norton Smile
Modern Honda and Harley
Post #476243 25th Nov 2015 11:31pm
Natlas
and a close up in case you can't get it from the first pic. The curved part of the pipe seems to go right back up to the top of the filler tube.
 2.2 90 XS
88" Series One
Old Norton Smile
Post #476244 25th Nov 2015 11:33pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Yes, the tank goes in on the first portion of the assembly line along with suspension, and exhaust, some wiring, steering and then the engine.
Post #476258 26th Nov 2015 12:57am
X4SKP
Thanks Natlas and CDN38
I'm sure now that the installation of the Fuel Tank during the assembly of a Defender 'to rolling chassis stage'
is achieved by placing the Tank down into the chassis i.e sitting it onto its metal 'protection tray'. This is in
line with generally a 'top down not bottom up' approach, as the Chassis gets built up.
It is possible that the Chassis gets flipped at some point but if the Tank installation on a 2.2 whilst different in detail is basically the same location principle as the 2.4, the Tank just locates within the available space (minimal in a 90) and if the Chassis above was inverted would fall out (all be it with the pipework attached).
The same end result applies, on assembly of the upper body, short of going through the floor, the Tank needs to drop down to get it out, OK on a 110 / 130 (I hear), at least for some... a Censored on a 90 SKIP
Post #476288 26th Nov 2015 9:55am
Page 2 of 3 <123>
