Home > Wheels & Tyres > Spare Wheel Security.
Page 3 of 3 <123
Edzi
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Alaska White
Very cool idea indeed and no additional drilling needed; nice Smile
Post #458616 28th Sep 2015 10:18am
K9F
X4SKP Now that is a damn fine piece of innovative engineering with a great finished look. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #458623 28th Sep 2015 10:34am
X4SKP
Why thank you Sir... Thumbs Up
Only a Day in the Workshop... Exclamation
Custom Bonnet Security almost there too... Wink
Happy Days... SKIP
Post #458626 28th Sep 2015 10:52am
K9F
I'd be very interested in the latter if it's engineered as good as the spare wheel one please? Being an electrical engineer I have added extra electrical security and a lock through the hoist but a discreet nevertheless noticeable mechanical one would be ideal. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #458652 28th Sep 2015 12:23pm
RRUK
K9F wrote:
Job done!
Mal,
Why is your spare so high up? It's totally blocking the rear vision and can't be easy to lift a big wheel up to that height to put it on? 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #458671 28th Sep 2015 1:46pm
K9F
RRUK the Safari Equipment Single Pivot Swingaway Wheel Carrier gives you two options of height adjustment, dependent on which way you fit the mounting bar. You can have the single stud uppermost thereby lowering the mounting position significantly.
Previously I had my windows tinted and as a result due to the reflective properties of the film applied I could see absolutely nothing through the rear view mirror except what was actually in front of me (hope that makes sense). When I eventually after 5 years swapped out the rear windows for Landyglass due to the fact it was the glass that was tinted (not a film application) I could then see again. Because of the size of the wheel/tyre combination and the spoke arrangement of the Mach 5s in the uppermost position I can see through the spokes what is close behind me. In the lower position I can only see vehicles at a distance which are of no real concern or interest. It is also easier to dismount the spare at chest height rather than midriff especially with my back. Mind you in nearly 40 years of driving I've only had to fit a spare in anger once. Windscreen replacements however are a different story. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #458674 28th Sep 2015 2:11pm
RRUK
I see. Nice bit of kit 2016 D4 HSE
Post #458740 28th Sep 2015 6:13pm
gw8izr
Wales
They are both nice setups, the one made by RRUK is much less likely to be removed with the universal key (battery grinder)
We had a spate of CATs stolen from our works vehicles, the tell tale grinder marks and sparks visible on the cctv confirmed the weapon of choice.
Post #458781 28th Sep 2015 7:53pm
Page 3 of 3 <123
