Home > Puma (Tdci) > What have I done?
Stiff1
What have I done?
So, in removing the centre console panel to replace the clock and hazard bulbs I have done something to the heater deflector knob. Upon refitting the panel the knob only turns to the first and second positions.
Had a fiddle but no obvious problems, any suggestion appreciated... let the innuendo commence.
Post #456985 22nd Sep 2015 2:12am
You probably have a cable or connector that has been disturbed and dropped down fouling the mechanism - dash off again !
Post #456994 22nd Sep 2015 6:46am
ericvv
I know which bulb is needed for the hazard switch, but never saw any post with the type of bulb for the clock.
Is it the same type as hazard switch, or if different, can you please inform us of the part number and of where you bought it?
Good luck with the dash off again, and thanks.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #456995 22nd Sep 2015 7:05am
Stiff1
Ericv - Used your post as a start point but most of the focus moved to the hazard bulb.
After all the miss-information it is so simple:
eBay Item No. 361324831214 (Bolt on Bits £4.99 green bulb so none of this felt tip pen stuff)
Remove centre panel, remove 4 small torx screws holding in clock (easy to drop them when reinstalling them)
Bulb comes in holder, unscrew (half turn) old unit and replace.
Put everything back together.
ENSURE YOU DONT MESS UP YOUR HEATER DEFLECTOR CONTROL
Go Beyond - My thoughts as well but can't find the problem, might have to completely remove it to examine in the house, afraid of disturbing something else though.
Post #457025 22nd Sep 2015 8:27am
Is it the rotary controls or the slider? Either of which it'll be a cable jamming it.
What ever you do don't try and force it.
Centre dash off and check. Thumbs Up
Post #457050 22nd Sep 2015 10:27am
Stiff1
Its the rotary control, out it comes then...
Post #457066 22nd Sep 2015 11:37am
