![]() | Home > Puma (Tdci) > What have I done? |
You probably have a cable or connector that has been disturbed and dropped down fouling the mechanism - dash off again !
I know which bulb is needed for the hazard switch, but never saw any post with the type of bulb for the clock.
Is it the same type as hazard switch, or if different, can you please inform us of the part number and of where you bought it? Good luck with the dash off again, and thanks. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 602 ![]() ![]() ![]() |
Ericv - Used your post as a start point but most of the focus moved to the hazard bulb.
After all the miss-information it is so simple: eBay Item No. 361324831214 (Bolt on Bits £4.99 green bulb so none of this felt tip pen stuff) Remove centre panel, remove 4 small torx screws holding in clock (easy to drop them when reinstalling them) Bulb comes in holder, unscrew (half turn) old unit and replace. Put everything back together. ENSURE YOU DONT MESS UP YOUR HEATER DEFLECTOR CONTROL Go Beyond - My thoughts as well but can't find the problem, might have to completely remove it to examine in the house, afraid of disturbing something else though. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20945 ![]() ![]() |
Is it the rotary controls or the slider? Either of which it'll be a cable jamming it.
What ever you do don't try and force it. Centre dash off and check. ![]() |
Its the rotary control, out it comes then...
