Home > For Sale & Wanted > [For Sale] Provent. Used. Reduced £70
landy andy
Selling the Provent that was fitted to my Tdci. Will also include the bracket that I made and used. Does not include hoses.
£80 plus the postage, can take to Petbog show this Sunday, or collection
Andy
Post #455992 18th Sep 2015 5:52am
landy andy
Must be too much money so £70
Post #456217 18th Sep 2015 9:39pm
K9F
Not in comparison to the average £120 new price for them. IF you can find a genuine seller not knocking on cheap Far Eastern copies. These are excellent pieces of kit, if not a little difficult to fit in an XS model due to available space. Achievable though as we both appeared to have cracked the solution one way or the other!
Thumbs Up
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #456287 19th Sep 2015 9:26am
theorangebandit
How do these plumb in ? Do they recirculate oil into the sump rather than the induction ? I am interested as I would like to reduce or remove the oil from the inlet
Post #456292 19th Sep 2015 9:45am
K9F
No any excess oil is filtered and collected at an outlet/pipe in the base of the filter housing to which you can fit a drain to periodically drain it off. It allows clean air without any oil mist being fed into your turbo preventing carbon build up in the turbo and/or oil migrating into the intercooler system.
This was RockJaw's solution for draining.
Any further questions and the answers to which will probably be found here:
http://www.defender2.net/forum/topic26798.html?highlight=provent If you go through life with your head in the sand....all people will see is an ar5e!!
Post #456310 19th Sep 2015 1:12pm
theorangebandit
Thanks for the link. I'll check it out later
Post #456334 19th Sep 2015 4:47pm
