![]() | Home > For Sale & Wanted > [For Sale] Provent. Used. Reduced £70 |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5999 ![]() ![]() |
Must be too much money so £70
Not in comparison to the average £120 new price for them. IF you can find a genuine seller not knocking on cheap Far Eastern copies. These are excellent pieces of kit, if not a little difficult to fit in an XS model due to available space. Achievable though as we both appeared to have cracked the solution one way or the other!
![]() ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
How do these plumb in ? Do they recirculate oil into the sump rather than the induction ? I am interested as I would like to reduce or remove the oil from the inlet
No any excess oil is filtered and collected at an outlet/pipe in the base of the filter housing to which you can fit a drain to periodically drain it off. It allows clean air without any oil mist being fed into your turbo preventing carbon build up in the turbo and/or oil migrating into the intercooler system.
This was RockJaw's solution for draining. ![]() Any further questions and the answers to which will probably be found here: http://www.defender2.net/forum/topic26798.html?highlight=provent If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Thanks for the link. I'll check it out later
