Home > Maintenance & Modifications > Gearbox drain plug won't budge
Telshe
England 2004 Defender 90 Td5 XS CSW Cairns Blue
To day l attempted to change the oil in my 04 ninety defender. The filler plug undone ok but the drain plug which was 3/8" square socket (not sure what right terminology) but not the usual plug with a copper washer. I gave up trying to budge it fearing l might strip it or something . What do you experts think I should try to shift this. I ended up just topping up the level it looked very clean. I used the Trailer Fitters trick of using a bent plastic tie.
Telshe
Post #455610 16th Sep 2015 7:18pm
mk1collector
The oil should not be topped up to the filler hole!!! Ray
My build thread
Post #455612 16th Sep 2015 7:20pm
excossack
Being an 04, it will be a TD5? I thought with the R380 the correct level was with the oil level with the filler plug? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #455629 16th Sep 2015 7:53pm
Fatboy Slim
Wales
Yes it should
Post #455630 16th Sep 2015 8:00pm
