Home > Maintenance & Modifications > Poweder coat / U-pol Raptor / Galvanize accessories
mcl001
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
Hi
I am a new member (like an excited little kid with Puma Utility Wagon - very different to a 300Tdi 110 I had a number of years back - still wish I had not sold it though!) so forgive me if this has already been covered.
I am intending to get front tubular bumper, swing away carrier and some rock sliders. Most things seem t be powdercoated but I don't think it is durable enough. Especially where I live near the coast.
Thought about trying to get everything galvanised but does not seem much available.
My options are:
1. Buy in powdercoat and paint with u-pol raptor for extra protection (and can touch up if scrapped?)
2. Buy in powdercoat and have stripped and galvanised (stuff I cant buy already galv)
What do you think?
Thanks MATT Very Happy
Post #454855 14th Sep 2015 7:32am
Barney12
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Welcome! Leave your wallet at the door!! Mr. Green
I'd say raptor was a good choice provided you don't want that 'showroom smooth' finish.
The problem with powdercoats is that it's a broad church in terms of quality. I'd say at the top end of the market though the finish will stand up to coastal weather. But, if it chips then....hello rust!
The Nakatenenga wheel carrier is stainless and powdercoated to a very high standard. But I accept not cheap.
HTH.
Post #454857 14th Sep 2015 7:58am
SailingTom
Hi Matt
Well done with the New Defender
Like you I live right on the coast, normally I take bits to our local trailer supplier and get them galvanized, Ive done this like you say with brand new parts in the past. Powder-coating on new accessories in most cases is simply not up to the job.
Hope this helps, thats what i'd do if I were you.
Cheers Tom
Post #454858 14th Sep 2015 8:01am
leeds
First welcome Matt..
There are makers of items such as tubular bumpers, rock and tree sliders etc. with that is a wide range of price and quality.
The cheaper end of the market tends to have just a quick blast over with a lick of paint or powder coated.
The other end of the market is hot dipped galvanised and then powder coated. That way if you damage the powder coating it does not rust.
Why buy a powder coated version, get it stripped, ensured it is drilled then hot dipped galv then powder coated? You will hit minimum charge quantities and have transport cost as well!
Safari Equip are local to us and their gear comes hot dipped galv then powder coated. It might cost you a bit more in the first place but could save you time and money in the long term.
Whell carriers? We can supply their range of wheel carriers hot dipped galv and powder coated. Or we can supply the Nakatanenga stainless wheel carrier either naked stainless or powder coated. The Nakatanenga range of wheel carriers is probably the best and widest range in the UK
Brendan, 4x4 overlander
Post #454859 14th Sep 2015 8:06am
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
Could you not speak to one of the UK manufactureres and just ask them to sell you one galv'ed but not powder coated? That way, you can have it coated with a Polyurea coating.
If you go this way, I beleive you need to ask the manufacturer to T-wash the item once Galvanised. This prepares the zinc to allow a primer to key to it.
Any decent galvaniser will tell you the process required.
Have a look at Blackline SV. They market Polyurea coating. They'll give you an idea of what is possible, although they seem bloody expensive. THey market it as the newest thing in the world, but it's been around a long time.
Mabe search truckliner near to you and ask them to coat your parts next time they've got the kit out to do a truckbed?
Could save you a few quid.
Post #454908 14th Sep 2015 10:45am
mcl001
Hi
Thanks for all the quick responses....
I don't mind leaving everything galvanised, I know it discolours in time but my galv trailer and work roof rack have faired well with building use
Even if powder over galv I think I will have to keep touching up?
Post #454942 14th Sep 2015 1:14pm
mcl001
I am hopefully going to Lro in Peterborough this weekend so I will see what is available hot dipped galv to start with
Cheers Very Happy
Post #454944 14th Sep 2015 1:17pm
leeds
May I suggest you come and look at our vehicles on stand J14.
You will see items which are brand new plus items which have been on our vehicles for up to 10 years.
R + T sliders, (someone says we abuse our vehicles I say we use them) then you will see how they stand up to use.
Brendan
Post #454955 14th Sep 2015 1:39pm
Litch
Just have the items galvanised yourself, that is what I have done over the years. Rear bumperettes, capping, side-bars, swing-away carrier, light-guards, steering guard bracket, battery-box, radiator surrounds, slam-panel, bulkhead etc etc etc.
The place I use is in Sawtry (less than 10-miles from Peterborough), they prep the items and then dip. Turnaround time is usually 2-3 days and while they have just introduced a minimum order of £50 you would be amazed at the volume of items this will include. ONE LIFE, GET IT!
Post #455084 14th Sep 2015 8:58pm
mcl001
Brendan
Thanks Brendan, if I make it up I will come by
Post #455109 14th Sep 2015 10:07pm
leeds
If you are having items galv and then powder coated make sure that they treat the galv properly after the hot dip process as this can effect how well the powder coating sticks to the galv.
Brendan
Post #455129 14th Sep 2015 11:23pm
