Home > Maintenance & Modifications > Rivnut question
AndyTunn
New Zealand 2008 Defender 90 Puma 2.4 SW Stornoway Grey
Rivnut question
I am going to end up putting a couple of rivnuts into my Defender's ali bodywork. What steps should I be taking to prevent corrosion whether disimilar metals, ali corrosion or the rivnut itself?
(Preferably things that don't involve hard-to-get lotions made of crushed himilayan anti-rust beetles - the range of products here in NZ is a lot more limited! Laughing )
Post #454349 12th Sep 2015 9:07am
need4speed
What load will the rivnuts be taking?
Why not use aluminium rivnuts then it's a non-issue...
Post #454365 12th Sep 2015 9:52am
K9F
'Wet assemble' it before squeezing the nut home using a decent sealant like Sikaflex. It will assist in slowing down any corrosion process that may commence. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #454366 12th Sep 2015 9:54am
smb
As K9F said Thumbs Up
Every rivet I've done I've used Sika sealant(black for a black truck) whether the rivets are Ali or steel. 3yrs on and never any corrosion/reaction. By the look of it they are lasting a lot longer and in better condition than that of Landrovers'.
Post #454379 12th Sep 2015 10:25am
nitram17
Pardon my usually daft questions but ali panel with ali rivnut ..what happens when you stick a stainless bolt or the like into said rivnut?
Post #454380 12th Sep 2015 10:29am
Alex1976
I coat the stainless bolt with Dynax S50 before screwing it into the Ali rivnut and that seems to stop any reaction. Basically wet assemble everything and you should be fine.
Post #454389 12th Sep 2015 10:56am
need4speed
What Alex said. If using a mild steel or stainless bolt within the ali rivnut then use some barrier between the 2 metals.
Other than that I think sometimes people can get a bit overly anal about things. I've had ali rivnuts fitted to my defenders ali panels for years with no sign of corrosion at all, and they were fitted dry.
Post #454402 12th Sep 2015 11:41am
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
I use Duralac.
Post #454413 12th Sep 2015 12:32pm
ericvv
Each to his own, while I have used Duralac before, after recommendation from a Defender wizzard I recently switched to Weicon anti corrosion paste, which I think is better. Duralac with time hardens up, experienced that first hand, Weicon remains soft/liquid which think is better for isolating two bodies in the long run and which in my opinion makes later undoing of for instance screws, etc. easier. Not sure about Weicon availability for you, but if you do a search on here with Weicon, you will find a few threads where I commented about it with pictures et al.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #454442 12th Sep 2015 2:13pm
AndyTunn
Thanks for the suggestions folks. I'll be following the ali rivnut and wet assembly path I think. Right-ho, off to the hardware store! Thumbs Up
Post #454570 12th Sep 2015 11:54pm
mk1collector
Is this for the a bar surrounds into the wings?
If so I put a bolt with a nut on the back of the wing instead of a rivnut, with the thinking that as the bolt that holds the surrounds to the wing is only about an m4 so if for any reason in the future the a bar needs removing a reasonably small rivet could be placed in the holes and not look too bad if painted. Also you can put I little insulation tape on the shank of the bolt and use a plastic washer behind the nut so there should be no dissimilar metal corrosion. Ray
My build thread
Post #454573 13th Sep 2015 12:01am
AndyTunn
Thanks for the info Ray, yes it's for the bar surrounds (well, initially - I also want to mount an auxiliary fuse box under the seat at some stage). I might have to go the nut and bolt option as the local hardware store didn't have any ali rivnuts - just plain steel. I presume you get access to the nuts by taking the headlights out? I have liners under my wheel arches that stop me accessing the inside of the wings that way.
Cheers, Andy
Post #454578 13th Sep 2015 1:22am
mk1collector
I popped a couple of the plastic clips off the arch liners, the centres just push through and then the clip pulls out (try and catch the centres from the back as you push them through) then the arch liner will move out of the way enough to get your hand in with a spanner. Ray
My build thread
Post #454646 13th Sep 2015 12:22pm
mikeh501
Try memfast. They sorted me with all my captive nuts and the quality was great. They even have rubber ones which are great for number plates and such like.
Post #454690 13th Sep 2015 4:23pm
