![]() | Home > Technical > prop shaft uj |
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2785
10
New UJ time |
| srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 |
Cheers!
10 - seriously? Think: 1 = new, 10 = worst ever seen/seconds away from total failure... |
Well perhaps not 10.
But really a UJ, once removed, is either f***ed or it's not - as you're not going to put it back on unless it's perfect. |
| Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 288
What's this then? Click image to enlarge Click image to enlarge |
Also f***ed!
| Timo K Member Since: 23 Aug 2012 Location: Helsinki Posts: 171
How's this? Swapped it for a new one today... |
So I showed mine to an ex-mechanic friend who rated mine an 8, but those look way worse!
Replaced it with a GKN part I got off ebay for £13.69. Rattle now cured! A nice straightforward, satisfying job with a positive outcome! |
| I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 882
If that is off your own vehicle then you should go and stand in the corner and hang your head in shame. That is terrible and must have been bad for a long time, not the sort of thing you could ignore for very long unless you have absolutely no mechanical sympathy. |
