Home > Puma (Tdci) > Heated Mirror Wiring
Morepower
New Zealand
Hi Guy's, Iv'e bought some heated mirror elements and have mounted them up and drilled the doors and run wiring through to the engine bay etc...
However, I'm undecided about the best way to power them... Do I piggy back of the screen wiring (so they come on with the heated screen)... Do I mount a secondary switch with a separate power feed etc etc...
Anyway... If any body has any pictures and wiring diagrams that would be much appreciated as I'm looking for any suggestions...
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #450740 31st Aug 2015 8:40am
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
Most common way is to wire them separately from a relay (usually in the seat box ner the battery. The activation pin on the relay is fed from a splice from the windscreen wiring. That way you're only using the windscreen wiring to provide a relatively low current to the relay, which provides an independent fused supply to the mirrors.
Generally wiring it to the window switch makes sense as you want the mirror heaters on when you need the window heated. Otherwise it'd be another switch taking up space on your dash!
Make sure you protect the cable when it passed through and sheet metal, and when it's near the doors, so it doesnt chafe and short out.
Post #450788 31st Aug 2015 11:03am
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Tim, you'll probably find this of interest
http://defender90xs.blogspot.co.uk/2014/10...ation.html 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #450794 31st Aug 2015 11:22am
leeds
Another set of photographs show installation HERE and slightly more info here
Brtendan
Post #450800 31st Aug 2015 11:40am
boode
England 2003 Defender 90 Td5 HT Rutland Red
Have a separate switch (and relay) for the heated mirrors
I find that in the rain/mist/drizzle the heat will keep the mirrors clearer from water and you would not want the heated screen on
Post #450802 31st Aug 2015 11:45am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Installing Mirror Heating to a Land Rover Defender by Espen S. Johnsen :
http://la7dja.org/defender/mirror-heating/ Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #451191 1st Sep 2015 8:57pm
Not once have I bothered with a separate switch I always used the heated screen switch with absolutely no issues Thumbs Up The draw is well within the switch and wiring tolerances
As always your motor your choice Thumbs Up
Post #451264 2nd Sep 2015 6:47am
Oh its 1.55 amp per side
Post #452394 5th Sep 2015 8:38am
Lops
England 2007 Defender 110 Puma 2.4 CSW Scotia Grey
so do you wire directly into the switch or off the relay? sorry electrical noob
Post #801220 7th Nov 2019 4:34pm
ZeDefender
Mine come straight off the screen wiring, as I always want them all on at once - haven't had a problem since I fitted them (8 years). Tell someone you love them today because life is short.
Post #801412 8th Nov 2019 10:48pm
