Home > Td5 > What is this switch?
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Just realized that I had this little SPST rocker switch under the dash, it appears that it is clock graphic or guage graphic on it? Can someone tell me what it does? Cannot seem to find any reference to it.
Cheers 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #448062 21st Aug 2015 4:18pm
PaulMc
It should enable you to turn off the instrument's background illumination when the headlamps are switched-on.
. Paul.
Post #448064 21st Aug 2015 4:24pm
4RF RDS
I had thought so too, but nothing happens with the dash lights. Must be disconnected or broken?? 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #448070 21st Aug 2015 4:50pm
PaulMc
If you use a small screwdriver under the front edge of the switch, you should be able to drop it out of the panel, to check and see if the wires are still attached to it.
. Paul.
Post #448072 21st Aug 2015 4:58pm
grafty99
is that a factory thing that fills the "mystery" hole on UK Tdi/5s? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #448095 21st Aug 2015 6:49pm
Martin
Site Admin
Most have a blanking plate in there. Perhaps this switch was added to control some other feature?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #448099 21st Aug 2015 6:52pm
rallysteve
Ours has an identical switch there (without the symbol) which operates the roof beacons.
Probably something someone added on aftermarket (spotlamps or similar)!
Post #448100 21st Aug 2015 6:54pm
PaulMc
YUF101590 - SWITCH, DASH PANEL, ILLUMINATION, '(+)"CDN/USA"'
http://www.brit-car.co.uk/product.php/9525...def_county
From Land Rover - £63.10 incl. VAT Shocked
A little bit cheaper from Lucas -
http://www.ebay.co.uk/itm/LANDROVER-DEFEND...0565339744
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #448105 21st Aug 2015 7:09pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Is it for switching the dash illumination on/off, or dimming the dash illumination from bright, to not so bright?
Post #448138 21st Aug 2015 8:41pm
PaulMc
On/Off
. Paul.
Post #448140 21st Aug 2015 8:46pm
4RF RDS
I think I have figured it out. Took the switch and panel off and tried tracing the wires. An OEM plug is spliced into two white wires leaving the bulkhead to the engine bay. They are most definitely not hooked up to the dash lights. It also turns out the switch is an on off on type not SPST. Odd set up as this was LR installed according to the build information I have. I believe it controls the currently non functioning drving lights on the bumper. i appreciate all the responses. It helped. Wierd placement for a switch though. I plan on installing a MUD Stuff centre dash console and will relocate this and few others.
1967 MGB GT
Post #448287 22nd Aug 2015 11:57am
4RF RDS
Yup finally found the relay it was NS and once I replaced it the lights work with that switch. 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #448327 22nd Aug 2015 4:18pm
