![]() | Home > Maintenance & Modifications > Defender C/V joints |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059
I've got a pair of cv's and front shafts that were removed from a Td5 with just delivery miles on them
Andy |
| appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630
If the OP doesn't have them, can I have second dibs please?
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039
By experience with my 90 Td5 with 35" Simexes, I have a feeling that none abs CV's are stronger then ABS CV's.
An ABS CV is the same as a None ABS CV but has ABS signal slots cut in the outer ring. My none ABS break the inner parts and the ABS CV break the out part. Click image to enlarge On the right 3 x a none ABS CV on the left on the plastic a new original LR ABS CV. (You might have to zoom in to see the difference). The ABS CV exploded very soon after this picture. 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
| All times are GMT |
