Home > Td5 > Fuel leak from top of the tank...
fumiyasu
 1999 Defender 110 Td5 SW Santorini Black
Hi all,
Got my new wheels and tyres installed on Sat and went to fill up the tank. Came back home and there was a fill drops of diesel dripping down... Sad
Did a bit of investigation, it seems to be from the top of the tank and it only drips when the it's running. So I think it's a seal or pipe after the fuel sender.
Does anyone have any experience with this kind of leak?
Mine's a 1999 so it looks like the tank might be hard to remove as the bolts are probably going to snap. (Snapped all the bolts on the load area seats when I removed them...) A local garage suggested cutting a hole in the load floor to repair the fault and then board it back up as the cheapest repair route...
Any suggestions?
Post #446719 17th Aug 2015 10:49am
jimbob7
Sounds like one of the (4)pipes has split,cost me £70 (the cheapest pipe anorl Shocked,I think a return from the fuel filter ) for a LR replacement,it split on the connector so dint know if it could be repaired,with a bright torch and one of them flexi extendable mirror things you can see exactly which one it is.Empty your fuel tank completely if your doing it on your own.Surprisingly the bolts came out easily,world of hurt if they don't (onna 110).Good luck!! Pov.spec,ftw. 2006, 110,TD5.
Post #446723 17th Aug 2015 11:03am
fumiyasu
Cool, sound like I just need to find a way to store 60litres of diesel... Probably try to get it into my other car which convienently is almost empty today.
Was it just 4 bolts and the tow bar to remove the tank? I am thinking I would probably give the bolts a go and see how easy or hard the are before taking it to someone...
Post #446728 17th Aug 2015 11:21am
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
I had to replace the fuel pump on my 90 (2000MY) ended up cutting access panel in floor as it looked like a git of a job to drop tank. Bought a stainless panel designed to cover the hole afterwards can post picture later if you like. Makes it easy to access if you need to again Thumbs Up
Post #446770 17th Aug 2015 1:51pm
fumiyasu
yes, would like to see that, I guess you just bolted it down?
Post #446773 17th Aug 2015 1:57pm
JWL
You might just want to look at this thread I did when I changed my pump as I didn't want to disturb the tow bracketry and reduce the likelihood of breaking anything when dropping the tank. It also allows you to sort things out when the fuel tank is nearly full Thumbs Up
http://www.defender2.net/forum/topic28189....+fuel+pump
Post #446774 17th Aug 2015 1:58pm
rallysteve
I did drop the tank but managed to snap one of the fuel line fittings whilst reassembling. A huge pain of a job to repair even using the metal replacements I got from 4x4overlander. The long fuel pipe which runs from tank to engine costs about £200, which was of course the one I damaged. I would advise cutting a hole in the floor!
Post #446788 17th Aug 2015 2:36pm
Oakseywick
Here is a picture of the cover I think the firm it came from are called 4muddyfeet.
Post #446869 17th Aug 2015 5:33pm
fumiyasu
Looks like hole in the floor is the popular solution. The muddy feet plate looks really good, didn't realise there was a purpose made product for this...
I do have a brand new Bosch angle grinder I brought a couple months back, maybe its time to test it out.
So once I ve cut a hole, I guess if its the shorter pipes that runs from the filter to the sender then its just a case of disconnecting each end and wiggle out?
Post #446879 17th Aug 2015 6:18pm
fumiyasu
Thanks JWL, just looked at your post and saw the strengthening ribs under the floor, did everyone else cut that too? Just thinking as I don't have ply or anything on the floor, would that make the floor flex more than it already is when someones on it?
Post #446882 17th Aug 2015 6:40pm
JWL
There is quite a lot of strength in the floor as it is but you could allways put an insert in along the lines of a manhole which would be more than enough. I've seen various inspection covers used including plastic ones out of the Screwfix catalogue used to access heating pipes and electrics found under floors.
Post #446884 17th Aug 2015 6:49pm
Oakseywick
Cut through floor rib aswell so good access for pump. No noticeable flex in floor, the plate is pretty strong.
Post #446983 18th Aug 2015 7:39am
fumiyasu
Cool, should be OK then, thanks both.
Post #447166 18th Aug 2015 6:49pm
