Home > Puma (Tdci) > Hole in Intercooler pipe
excossack
Is there/was there a recall for 2.4 Pumas for the steering UJ rubbing a hole in the pipe? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #446836 17th Aug 2015 3:50pm
No, I don't think so. It's a widespread 'feature' but as far as I know has never been a recall. Under warranty it was fixed FOC, but outside warranty it's DIY.
On the 2.2 there was - I think - a recall for the intercooler pipe rubbing on the alternator.
Post #446843 17th Aug 2015 4:16pm
ericvv
Re: Hole in Intercooler pipe
Never heard of that problem you mention there for the 2.4, but there are a good number of standard intercooler pipes that eventually will split due to the pressure. I have had that experience, and in the end replaced the standard pipes by stainless steel version.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #446845 17th Aug 2015 4:20pm
K9F
2.2 Yes there was a recall....for this issue below.....
http://www.defender2.net/forum/topic20804.html?highlight=rubbing
Not so for the 2.4 but mine did chafe too. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #446848 17th Aug 2015 4:25pm
Like Ericvv, I replaced the intercooler pipes on my 2010 110 (only 18k miles) With entreq stainless pipes. interestingly the hose from the turbo to intercooler had an indentation from what looks like a bolt head rubbing against it. it had not burst but may not have lasted too much longer. The pipe from the intercooler to inlet manifold if still like new.
Post #446853 17th Aug 2015 4:38pm
excossack
Cheers chaps. I was'nt sure if there was a recall or not. It came about because I was coming home from a rally at the weekend and saw a 90 broken down. On getting closer, I knew the people in the 90.
Idler pulley had seized, so belt had gone and also a hole in the intercooler pipe caused by the steering UJ rubbing through.
I will pass on the info.
PS Last thing you need is UJ chaffing on things! 1999 Defender TD5 110
Regards
John M0VAZ
Post #446998 18th Aug 2015 8:34am
