Home > Technical > Help - how to remove this odd nut
CFB
Anyone any idea what to use to remove this odd nut?
Held a LED light bar on a bracket and it wont budge with mole grips etc
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Andy
Post #444495 9th Aug 2015 1:22pm
gilarion
You could try grinding a notch and then use a flat drift and a hammer to loosen it. First spraying with release oil. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #444499 9th Aug 2015 1:27pm
CFB
That might be the only way, looks like it had some sort of tool supplied initially like a locking wheel nut key perhaps? Andy
Post #444500 9th Aug 2015 1:29pm
discomog
Yes what you need is called a "pin spanner". You should be able to use it in the two holes at 10 o'clock and four o'clock. Do a Google search for pin spanner and you'll see what I mean.
Post #444502 9th Aug 2015 1:30pm
Defender2014
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi,
If you don't need to keep the nut and similarly to Gilarion grind into the nut on the side furthest away from the large tube but 90deg to it.
Once your very nearly through, so you don't end up cutting through the bracket, drive a chisel into the cut and the nut should split open enough to loosing it from the threads.
Hope this helps ☺ Defender Puma 110XS SW
Kawasaki ZX9R El
Suzuki RGV250M
Honda CB250N Super Dream
Post #444506 9th Aug 2015 1:37pm
gilarion
Another though if you have a grinder they usually come with a pin spanner to assemble the disk to the machine, you may be lucky and find the pins will fit in two of the holes. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #444509 9th Aug 2015 1:39pm
Cupboard
you can get adjustable pin spanners, or as gilarion says try one from a grinder.
You should be able to put a punch at an angle in the hole and knock it round too.
If you really get in a muddle, measure them and I'll see if we've got a spare grinder key of the right size. You get a new one with each grinder and we've got stacks of all sorts of sizes, some of which don't fit any of our current grinders.
Post #444593 9th Aug 2015 6:06pm
nitram17
Re: Help - how to remove this odd nut
off the wall idea!two large screws (must be tight)or bolts that you can screw into two of the holes and use a bar across these to turn the nut!
Post #444600 9th Aug 2015 6:21pm
LR90XS2011
drill a hole in a bit of strip or something similar and arc weld it on, the heat from welding will loosen the nut and then use the strip to undo it DEFENDER 90 TDCI XS,
Post #444624 9th Aug 2015 7:18pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Not as daft as it sounds ...... We usually tap a couple of roll pins into two holes and use a prybar across them to undo Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #444657 9th Aug 2015 8:22pm
Windowlicker
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
Needle nose pliers, the thickest that will fit into the holes, open them out, insert.
Push down on the handles whilst levering with a flat blade screwdriver, or podger, or similar which is passed through the jaws of the pliers.
Or any of the other suggestions will maybe do the job, assuming it isn't horrendously seized in place, then heat and patience are your friends Thumbs Up "Procrastination is the thief of time"
Post #444665 9th Aug 2015 8:54pm
shaggydog
Weld a nut onto it and then undo it with a socket Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #444852 10th Aug 2015 12:06pm
gilarion
Have you had it off yet Laughing For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #444921 10th Aug 2015 3:49pm
