Page 836 of 1392 <123 ... 835836837 ... 139013911392>
DOOFER
fitted the trucklites and went for a bimble down the coast to Aldeburugh, i think i need to lose the safari snorkel, i'm never going to wade deep enogh to need it
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  DON'T PANIC
Post #443945 7th Aug 2015 9:38am
Terryt
New hub oil seals fitted.
Post #444310 8th Aug 2015 5:12pm
JWL
Bit of time on my hands today so I relocated the new led worklight to the middle of the motor and fitted the reversing camera that's been sat in a box for the past 6 months.
And they both work!
Post #444326 8th Aug 2015 6:36pm
YOLO110
Australia
Thumbs Up YOLO... You Only Live Once...
Post #444330 8th Aug 2015 6:51pm
stanley
Fitted the dash cam
Post #444355 8th Aug 2015 9:03pm
Pickles
Hello from Aus.
What are the buildings behind your Defender?
Pickles.
Post #444366 8th Aug 2015 10:20pm
JWL
That's a Martello Tower isn't it? Built to keep Bonaparte out of England.
Post #444371 8th Aug 2015 10:47pm
mk1collector
Picked up a pedal lock from 90mojo for the mrs double cab Ray
My build thread
Post #444379 9th Aug 2015 12:51am
DOOFER
Pickles wrote:
Hello from Aus.
Pickles.
http://www.landmarktrust.org.uk/search-and...tower-9317
here you go pickles
Post #444388 9th Aug 2015 7:39am
excossack
Had a fight replacing the front shocks and spring (done one side.....almost)
Once the shock was out the spring came out easily and new one went in OK as well.
Spent 2.5 hrs yesterday for one side. Top shock nut seized as was the bottom one.
Anyways after a fight with the grinder, buzz gun and swearing its out.
Shock out and spring out.
1.45hr today just finishing the passanger side. (well almost)
Its all back together now the only Censored is the top shock bolt in the turret.
How the hell do you compress the bushes enough to get the top wash on and the nut?
I can get the nut on to pull the shock up, but as soon as i remove the nut, the top of the shock goes too low to get the washer and the nut on?
Please....How...!!!!!??????
The otherside is going to a garage to do. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #444443 9th Aug 2015 11:54am
consumerize
United Kingdom 2004 Defender 90 2.5 TD SW Java Black
Im sure someone more professional than I will have a better suggestion, but when i did mine, I'm petty sure i put a trolley jack under the front axle and jacked it up to compress the spring / bushes to get the nuts on and tighten up.
Post #444447 9th Aug 2015 12:10pm
excossack
Sussed! I took a break grabbed a brew and youtubed! Ended up with a Devon 4x4 video and sussed what I had done wrong.
When resembling the shock I had the top bushes in the wrong order. I had two bushes below the top of the turret, instead of one below and one on top!
Now that's sussed it took me 15mins to put right. 1999 Defender TD5 110
Regards
John M0VAZ
Post #444466 9th Aug 2015 1:22pm
YOLO110
Australia
youtube is your friend! Cool YOLO... You Only Live Once...
Post #444618 9th Aug 2015 8:06pm
excossack
It was in this case
Regards
John M0VAZ
Post #444620 9th Aug 2015 8:11pm
Useful video that, especially just for general guidance.
Post #444644 9th Aug 2015 8:57pm
