Home > Maintenance & Modifications > Parts needed to replace front springs/shocks
Page 2 of 3 <123>
Interesting, I drive rough roads on a regular basis with lots of vibration.
Obviously excess vibration causes wear on various components.
I need to change springs and shocks myself this year so these might well be worthwhile.
Post #442717 3rd Aug 2015 1:13pm
shaggydog
I have these fitted on the front and the thinner versions for the rear
The fronts are castellated, the rear ones are more like a thick bike inner tube and really don't seem to do much at all.
The front however did (in my opinion) make quite a difference to my 110
Pic showing how they fit.
On a 110 the rear springs are thicker and larger diameter so they don't fit hence the inner tube type but if you have a 90 you can fit the castellated ones all round.
Be warned, you can do them top and bottom but if you do you have to use a spring clamp as I found mine kept wandering around.
If your doing a spring change or damper change I would recommend doing them but I wouldn't set out to do it specially as the difference is very subtle. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #442720 3rd Aug 2015 1:21pm
excossack
Would you notice vibrations from the suspension? Mine will feel much better (its does already from just the rears being done).
According to the LR Parts catalogue there should be some on the rear as well but between the lower spring mount and then spring
http://new.lrcat.com/#!/1228/7048/7554/674/7627
Part No. 22
But non on my 110 other than the rubber sleeve over the first few coils. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #442721 3rd Aug 2015 1:21pm
shaggydog
That is the bike tubey bit Thumbs Up
It just slips over the spring so it would be the rubber sleeve you see your other 110 Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #442724 3rd Aug 2015 1:26pm
excossack
Sod it. A pair ordered for the front! 1999 Defender TD5 110
Regards
John M0VAZ
Post #442725 3rd Aug 2015 1:28pm
munch90
I got them fitted top and bottom !
only because I had them , and lifts suspension small amount
Post #442727 3rd Aug 2015 1:33pm
excossack
I am just going to go between the top coil and the spring mount 1999 Defender TD5 110
Regards
John M0VAZ
Post #442731 3rd Aug 2015 1:40pm
Why thicker on the front and thinner on the rear?
Surely also what ever you do use it has to be very robust like Munch was pretty much suggesting or they'll just fail.
Not sure exactly what mine has on, none as far as I'm aware as its aftermarket springs anyway.
I was looking into the D44 turrets too with D44 HD turret rings.
This is something that I'd have to look at as the D44 rings appear thicker than genuine.
So those coupled with isolators might be a bit of lift put together.
So maybe in that instance thinner isolator front thicker rear.
I have no problem with genuine turret rings but the fact is the OE turrets are a pain for shock removal or bush changes.
And of course you can't have D44 turrets with OE turret rings due to the fact the captive bolts aren't long enough I believe.
I'm still wondering if I'd need to buy a spring compressor just to make the job easier.
Post #442733 3rd Aug 2015 1:41pm
excossack
I removed the rear springs without compressors, but it made life easier to install new ones when compressed. I guess I could have done without if I undid the rear ARB to axle mount. But as I had the spring compressors I used them. 1999 Defender TD5 110
Regards
John M0VAZ
Post #442735 3rd Aug 2015 1:46pm
Here's the D44 turrets:
£96 a pair, rings £20 a pair or there abouts.
Genuine turret rings are £32 or were last year.
Post #442740 3rd Aug 2015 1:56pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Galvanised are a better bet, they area round £40-45 Thumbs Up
http://www.paddockspares.com/galvanised-sh...g-kit.html 2014 110 2.2TDCi XS Station wagon - GONE
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - GONE
2024 110 D250 X-Dynamic HSE
Post #442745 3rd Aug 2015 2:18pm
Britpart. Shocked
Post #442788 3rd Aug 2015 4:23pm
Windowlicker
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
I had x8 rubber spring isolators fitted last week.
I got them from First Four , around £45 ish for the 8 of them.
They are around 10-12 mm depth a piece, and have effectively given the 90 a 1" lift all round, with one at the top , and one at the bottom of each spring.
This looks a bit better as it was a bit sagged with the various things I have fitted, and carry, and I swear, no placebo
b ollocks, it genuinely feels, less harsh clattery over all surfaces, in a word, just like I have rubber seperating metal to metal parts....
Which I have Laughing
It's subtle, but it's almost like I have reduced the tyre pressures all around. "Procrastination is the thief of time"
Post #442792 3rd Aug 2015 4:41pm
jomara
Bad example Steve Laughing Laughing
They're also available from alternative manufacturers Thumbs Up Thumbs Up
Not a fan of playing blue box bingo Laughing 2014 110 2.2TDCi XS Station wagon - GONE
Post #442795 3rd Aug 2015 4:44pm
Glad I saw this post regarding the isolators, it's not a job you can do ad hoc either so bets to fit and forget. (Hopefully)
Post #442807 3rd Aug 2015 5:57pm
Page 2 of 3 <123>
