Home > Maintenance & Modifications > Spacers to improve turning circle?
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi all,
Would fitting spacers w/ stock boost alloy wheels, in an effor to improve the turning circle, have a negative effect on bearings?
Post #44133 2nd Nov 2010 9:46am
MK
Just regrease my bearings and they were fine after 40000km. Driven with alloy+30mm spacer or 8" modular with 285s. Probably CV�s are more stressed if you adjust the turning circle. Puma 110" SW
Post #44137 2nd Nov 2010 10:51am
eutek
Thanks...
It wouldn't be for my 110, rather thinking of a 90. Mrs. eutek has started to drive the 110, and we're considering possibly replacing her Merc with a 90 in the future. Part of that however would be making the 90 slightly easier to drive.
Post #44144 2nd Nov 2010 11:42am
Fitting spacers won't affect the bearings any more than fitting wheels with a greater offset would. It will in theory marginally increase bearing loads but only by an amount which is insignificant compared to the normal driving and vehicle usage loads.
Spacers - and wheels with greater offset - are (of course) normally fitted to restore the turning circle lost through the fitment of wider tyres. Fitting spacers in an attempt to reduce the turning circle with standard tyres is probably not such a good idea since doing so will result in the cv joints in the hub working at greater angles than they are designed to do. Whilst this may not be an immediate problem, it certainly increases the possibility of joint damage and trouble.
Post #44148 2nd Nov 2010 12:35pm
RED-DOT
I am thinking of adding spacers to my 90 with 265's on SVX rims. Any recommendations as to a good make and size?
Thanks. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #44151 2nd Nov 2010 1:13pm
eutek
Thanks for the detailed response blackwolf...
I'd rather not risk anything, so she'll just get used to the turning circle as it is. Very Happy
Post #44152 2nd Nov 2010 1:13pm
I have 30mm spacers on my DC (which has 285/75 KL71s on standard Boost alloys) which I bought from Rakeway. They seem to be a top quality product, and the firm is well known for excellence in engineering. I chose these because I didn't want 'unbranded' ones, especially since on a fairly thin spacer like 30mm there isn't much material under the nuts; I wanted top quality, The 30mm spacers just keep the tyres under the wheel arch flares.
I bought them directly from Rakeway (phone no is on their website) and although I cannot remember the price it was significantly less than some of the ones you see advertised. I ordered them in the afternoon, paid by credit card over the phone, they arrived the next day. Excellent service.
The guy I spoke to was also able to advise me re. the torques for the original and new studs (120 lbft to hold the spacers to the hub and the standard 98 lbft to hold the wheel to the spacer) and also stated categorically that the advice widely bandied about on other forums to use loctite on nuts holding the spacer to the hub is unnecessary and bad advice. Torque 'em down correctly and they don't need threadlocking.
The Rakeway 30mm spacers (and possibly some of the other thinnish ones) come with the nuts to hold them to the hub. If you choose another make, it is worth checking if you need nuts. The ones supplied with mine look like standard LR nuts for steel wheels, but I am not sure if they are.
Since fitting them I have had no balance issues, no vibration, and to date no problems of any kind (these all seem to come as free extras with cheap spacers)!
Post #44162 2nd Nov 2010 3:32pm
toshers
Scotland 2011 Defender 110 Puma 2.4 USW Orkney Grey
Another here to recommend Rakeway. I also have a set of their 30mm spacers fitted...excellent product & service.
Post #44164 2nd Nov 2010 3:41pm
RED-DOT
I will follow your advice and go for the Rakeway... Ta!! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #44165 2nd Nov 2010 3:51pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
I also had a set of Rakeway and can recommend them Thumbs Up
Post #44196 2nd Nov 2010 11:07pm
BigMike
As with most Equipment it depends on the use of the vehicle. If you're doing a lot of desert corrugation then I would loctite every time. If mainly for road then torque would be enough in my experience
Post #44198 2nd Nov 2010 11:13pm
shingwell
I have a 130, but drove a 90 the other week. The turning circle seemed great!
Post #44213 3rd Nov 2010 2:13am
110SEB
Is a turning circle an optional extra? I don't think our 110 has one Rolling with laughter
Post #44220 3rd Nov 2010 8:29am
BigMike
I have 30 mil spacers and 265 tyres and they make a massive difference to the turning circle. Some of the tracks I do have very tight corners, and without the spacers it makes life much tougher, particuarly if I have to reverse up very steep and loose ground or slippery rock to make a turn. If any of you know the Lakes lanes then Stile End in particular from the farm direction going up through the S bends, and Walna Scar (when it's open). Gatesgarth too can be tricky without spacers in a Puma if there is ice and snow. Mine were �164 inc vat from west coast.
Post #44226 3rd Nov 2010 10:30am
MK
They are a must to turn on "mexican switches" in the Andes Thumbs Up Puma 110" SW
Post #44229 3rd Nov 2010 10:46am
