Home > Technical > clutch / box
Page 4 of 5 <12345>
K9F
Yes! JSTFU and change it quietly. It'll be a small price to pay with all the other unecessary items you've splashed out on in the pusuit of excellence and quietness. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #441691 30th Jul 2015 5:28pm
Happyoldgit
Caterham wrote:
Bla bla bla I'm spitting feathers.....grr!
Driving home clash band gear changes but low and behold just come off the phone.....one of the bits down by the clutch slave cylinder is called a DAMPER!!! Could it be it damps the clutch action to make it smooth?
The Clash were on the phone helping you find the right bits you imagine you need for your Defender - I'm impressed! Steve.
http://forums.lr4x4.com
Post #441862 31st Jul 2015 9:54am
Caterham
Rolling with laughter .....
flaming wish I'd known there was a restrictor / damper down there before.......to my mind now it makes perfect sense !!
(it was supposed to read......crash bang !) Laughing
have a great weekend ......I plan to have a great day Saturday Very Happy
I just feel sorry for the poor sod who's gonna have to put up with my non stop wittering about this n that and bl**dy this and broken that.........
n a few feathers for good measure ..... and perhaps the clash will turn up too Rolling with laughter
Thumbs Up
Post #441906 31st Jul 2015 12:44pm
mk1collector
Shocked that's us lot for the last few years!!! Ray
My build thread
Post #441918 31st Jul 2015 1:02pm
Caterham
..... O
Post #441929 31st Jul 2015 1:27pm
The hydraulic restrictor for which I gave you the part number is the "damper".
It allows full flow in the "disengage" direction but restricts the flow in the "engage" direction. It is fitted because otherwise if your foot slips off the clutch, the massive torque of the Puma engine will destroy the driveline. Fitting the restrictor means that the clutch doesn't just bang in instantaneously, it takes a (very short) time as though you'd released it quickly rather than instantaneously.
I have however found that the restrictor can get bunged up, which means that the clutch actually engages more slowly than your foot is moving. I always double-declutch and there can be problems if the movement of the clutch doesn't keep up with the movement of your foot.
Post #441935 31st Jul 2015 1:56pm
Caterham
yes - thanks BW.
presumably ? it could also get stuck to allow full flow in the engage direction too?
Post #441936 31st Jul 2015 1:59pm
Yes, but (a) it is probably less likely, and (b) in normal use you won't see any difference.
You could test it by letting your foot slip off the pedal. If the vehicle lurches into motion then the restrictor is restricting. If there a bang followed by a graunching noise and no movement of the vehicle, then it wasn't.
I think perhaps it might be best if you don't try this test!
Post #441958 31st Jul 2015 3:17pm
munch90
if your lifting your foot off the pedal slowly , then the valve will make no difference at all , weather its there or working or stuck full flow
Post #441959 31st Jul 2015 3:21pm
Caterham
Hmm.....in that case i'm back to drawing. Why else then could pulling away and changing gears go from lovely n smooth to a sharp / sudden take up? This isn't just being a carp driver as the above symptoms can from pulling away slowly in first at tick over?
Post #442018 31st Jul 2015 6:51pm
jst
if you change the restrictor just match it to the connector between the slave and the restrictor. The bore and OS dia of them varies between manufacturer. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #442528 2nd Aug 2015 8:40pm
Caterham
Thank you the note jst.
Don't ask me how but after fitting the new axle the clutch take up etc has been fine?
Post #442595 3rd Aug 2015 8:52am
I think your Defender might have something in common with Stephen King's creation "Christine"!
Post #442649 3rd Aug 2015 10:38am
jst
no worries
a new axle? bloody hell you must off road a lot to need one of those. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #442669 3rd Aug 2015 11:06am
Caterham
thought I'd replied to this already?
no off roading. IRB did me a deal that to my mind was both exceptional and made perfect sense. rather than waste time looking for the problem and paying for parts and bear in mind there was a recall on the axle case, the diff was of the 2 pin variety and the components has all done 58k miles to my mind it made perfect sense, especially as I was having new shocks too.
any how job done and still not had a poor gear change yet (other than due to driver error) Very Happy
Post #443295 5th Aug 2015 8:29am
Page 4 of 5 <12345>
