![]() | Home > Technical > clutch / box |
Yes! JSTFU and change it quietly. It'll be a small price to pay with all the other unecessary items you've splashed out on in the pusuit of excellence and quietness. If you go through life with your head in the sand....all people will see is an ar5e!!
The Clash were on the phone helping you find the right bits you imagine you need for your Defender - I'm impressed! Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
![]() flaming wish I'd known there was a restrictor / damper down there before.......to my mind now it makes perfect sense !! (it was supposed to read......crash bang !) ![]() have a great weekend ......I plan to have a great day Saturday ![]() I just feel sorry for the poor sod who's gonna have to put up with my non stop wittering about this n that and bl**dy this and broken that......... n a few feathers for good measure ..... and perhaps the clash will turn up too ![]() ![]() |
![]() My build thread http://www.defender2.net/forum/topic17615.html |
..... O
yes - thanks BW.
presumably ? it could also get stuck to allow full flow in the engage direction too? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
Yes, but (a) it is probably less likely, and (b) in normal use you won't see any difference.
You could test it by letting your foot slip off the pedal. If the vehicle lurches into motion then the restrictor is restricting. If there a bang followed by a graunching noise and no movement of the vehicle, then it wasn't. I think perhaps it might be best if you don't try this test! |
if your lifting your foot off the pedal slowly , then the valve will make no difference at all , weather its there or working or stuck full flow
Hmm.....in that case i'm back to drawing. Why else then could pulling away and changing gears go from lovely n smooth to a sharp / sudden take up? This isn't just being a carp driver as the above symptoms can from pulling away slowly in first at tick over?
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8397 ![]() ![]() ![]() |
if you change the restrictor just match it to the connector between the slave and the restrictor. The bore and OS dia of them varies between manufacturer. Cheers
Thank you the note jst.
Don't ask me how but after fitting the new axle the clutch take up etc has been fine? |
I think your Defender might have something in common with Stephen King's creation "Christine"!
no worries a new axle? bloody hell you must off road a lot to need one of those. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
thought I'd replied to this already? no off roading. IRB did me a deal that to my mind was both exceptional and made perfect sense. rather than waste time looking for the problem and paying for parts and bear in mind there was a recall on the axle case, the diff was of the 2 pin variety and the components has all done 58k miles to my mind it made perfect sense, especially as I was having new shocks too. any how job done and still not had a poor gear change yet (other than due to driver error) ![]() |
