![]() | Home > Maintenance & Modifications > Badge Adhesive |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
brake cleaner
or you can get proper glue remover |
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243
Autoglym intensive tar remover
Steve 02' 110 TD5 Double Cab Rebuild Thread |
| RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2038
Any alcohol base stuff will get rid of it, I used petrol in the past.
Ideally get one of these , makes life so much easier. http://www.ebay.co.uk/itm/STRIPE-REMOVING-...2803fb5d87 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
| steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2076
I used the AutoGlym sticky remover from Halfords.
I also used the dental floss |
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
Turps to remove the glue, Meths to clean off the turps
| Barney12 Member Since: 09 Jun 2015 Location: South West Posts: 744
These are fine in the right hands and used properly but just bear in mind that friction creates heat and heat can ruin your paint. Attack your paint with one of these on a high drill speed and too much effort and tears will follow. Sorry not meaning to teach anyone to 'suck eggs' |
Or just an automotive grade panel wipe. Its blooming handy stuff to have around for general degreasing and will cost you no more than £10-15 for 5LTR at a decent factors.
| gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5141
Don't use a heat gun unless it has a very low setting. I have used a hair dryer in the past with some success. Any solvent you use, no matter what, test first on a part of the paint work you cannot see. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
In this instance a very small amount of petrol would probably surfice.
Wear a pair of gloves and only use a small amount for safety's sake. (Not that you need telling) |
| robertcoby Member Since: 26 Aug 2014 Location: lothian Posts: 29
Angle grinder or grit blaster
| discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2543
That 's just blown another theory - that the Scots don't have a sense of humour! LOL
I think the angle grinder would only really work if you soften the adehsive with petrol first |
To soften the adhesive use petrol then use a blow torch
Having removed all the bonnet and tailgate lettering, number plate fixings and tailgate strips off numerous Range Rovers, I think I can handle it! It's not hard though.... 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
