Home > Maintenance & Modifications > Badge Adhesive
discomog
Badge Adhesive
Looking for advice. I want to remove the oval plastic Land Rover badge from rear quarter panel. I shall use the heat gun to warm up the badge and adhesive and then remove it using dental floss to separate the badge from the backing/adhesive. The advice I am looking for is what is the best solvent to use to dissolve the adhesive and remove it from the paintwork. Obviously I do not want to be too aggressive as I don't want to damage the clear coat. Thanks
Post #441894 31st Jul 2015 11:25am
munch90
brake cleaner
or you can get proper glue remover
Post #441895 31st Jul 2015 11:28am
rallysteve
Autoglym intensive tar remover
Post #441896 31st Jul 2015 11:31am
RRUK
Any alcohol base stuff will get rid of it, I used petrol in the past.
Ideally get one of these , makes life so much easier.
http://www.ebay.co.uk/itm/STRIPE-REMOVING-...2803fb5d87 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #441897 31st Jul 2015 11:31am
steve E
Wales
I used the AutoGlym sticky remover from Halfords.
I also used the dental floss Very Happy
Post #441899 31st Jul 2015 11:44am
Turps to remove the glue, Meths to clean off the turps
Post #441901 31st Jul 2015 12:10pm
Barney12
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
These are fine in the right hands and used properly but just bear in mind that friction creates heat and heat can ruin your paint. Attack your paint with one of these on a high drill speed and too much effort and tears will follow.
Sorry not meaning to teach anyone to 'suck eggs' Mr. Green but you never know who might read this thread in the future.
Post #441913 31st Jul 2015 12:52pm
Barney12
Or just an automotive grade panel wipe. Its blooming handy stuff to have around for general degreasing and will cost you no more than £10-15 for 5LTR at a decent factors.
Post #441914 31st Jul 2015 12:54pm
gilarion
Don't use a heat gun unless it has a very low setting. I have used a hair dryer in the past with some success. Any solvent you use, no matter what, test first on a part of the paint work you cannot see. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #441951 31st Jul 2015 2:48pm
In this instance a very small amount of petrol would probably surfice.
Wear a pair of gloves and only use a small amount for safety's sake. (Not that you need telling) Very Happy
Post #441964 31st Jul 2015 3:42pm
robertcoby
Angle grinder or grit blaster Laughing
Post #441998 31st Jul 2015 5:36pm
discomog
That 's just blown another theory - that the Scots don't have a sense of humour! LOL
Post #442003 31st Jul 2015 5:51pm
Barney12
I think the angle grinder would only really work if you soften the adehsive with petrol first Thumbs Up
Post #442008 31st Jul 2015 6:12pm
robertcoby
To soften the adhesive use petrol then use a blow torch Rolling with laughter
Post #442014 31st Jul 2015 6:33pm
RRUK
Having removed all the bonnet and tailgate lettering, number plate fixings and tailgate strips off numerous Range Rovers, I think I can handle it! It's not hard though.... 2016 D4 HSE
Post #442015 31st Jul 2015 6:35pm
