![]() | Home > In Car Electronics > How to program alarm fob |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
first thing rather than replace and programme new fob is to check the battery mounting cage inside the old fob , quite common on the style of fob is for the soldered joints of where the cage goes though the printed circuit board to break , quite a easy repair if your good with soldering iron
button mountings inside on the fob as well , but not quite so easy to repair IF YOUR NOT GOOD WITH SOLDERING IRON , FIND SOMEONE WHO IS as its easy to get solder in wrong bits and knacker if it needs replacing then I think a nanocom etc can do it or easier still www.remotefob.co.uk |
| adricons Member Since: 02 Jul 2015 Location: London Posts: 8 |
Thanks...will check that right away..ch appreciated!
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
munch90: that link's not working for me, did you mean http://www.remotekey.co.uk/ ?
yes should be www.remotekey.co.uk
I typed remotekeyfob see it was wrong then deleted the wrong bit |
I had a fob from them a month or so ago and it's working well.
But if you've already got a fob and just want to program it I don't think they can help can they? |
| jonny2tanx Member Since: 06 Jul 2014 Location: Harpenden, Herts Posts: 156
Buy a used fob off Ebay and get someone with a Nanocom to programme it for you.
http://www.ebay.co.uk/itm/LAND-ROVER-DISCO...3cf2e5e557 http://www.ebay.co.uk/itm/MG-ROVER-RANGE-L...1c54fbbd13 I'd happily programme it for you if you fancy a trip to Herts |
Thanks to you all...in the end I used www.remotekey.co.uk
Worked like a dream. Ordered Fob yesterday and received this morning. Took 30 seconds to program and then I send back device they sent to me in envelope they provide. Inc postage this has cost me £69.98. Very happy not to have had to deal with the Land Rover dealers who wanted my car for a whole day in 2 weeks time to do this tiny job. |
| All times are GMT |
