Home > Off Topic > Plastering
Tia4
United Kingdom 1998 Defender 90 300 Tdi SW Cairns Blue
Plastering
After a bit of advice need to sort out a bathroom ceiling its lath and plaster with a few cracks but otherwise sound should I over board first then plaster or will I be ok to plaster over the top.also it's Been painted so does this need to see led with pva first.
Post #437311 12th Jul 2015 9:56pm
jaydt
2011 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Personally I would overboard and use plasterboard screws and not nails then skim without the need to pva.
Post #437323 12th Jul 2015 10:25pm
Barney12
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Personally i would overboard it with plasterboard and then skim. That way you'll prevent/reduce future re-cracking.
It will be warmer too.
Post #437324 12th Jul 2015 10:26pm
familymad
Double tack it and then plaster over 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #437325 12th Jul 2015 10:29pm
K9F
Had a loft conversion a few years ago and the disturbance caused the plaster to break off the lathes, it was only the paper holding the ceiling up. Just pulled the lot down, plaster-boarded and skimmed.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #437335 12th Jul 2015 11:10pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Over sheet it with plasterboard and skim it, gives the best finish Thumbs Up 2014 110 2.2TDCi XS Station wagon - GONE
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - GONE
2024 110 D250 X-Dynamic HSE
Post #437341 13th Jul 2015 12:03am
