![]() | Home > Maintenance & Modifications > Washers? Loctite blue? TD5 axles / R380 / T-Box |
Yorkshire90 Member Since: 22 Sep 2011 Location: Yorkshire Posts: 205 ![]() ![]() |
For the final part of my 90's service I'm changing the oils throughout.
1) Do any of the axles have copper washers like the sump that need renewing? 2) Do the R380 or Tbox? 3) Just used some loctite blue on the Femco drainplug I installed on the engine sump. Is it worth adding a bit of loctite to any the above? Cheers ![]() SOLD Discovery 3 TDv6 GS Auto 2011-2012 *Missed the Defender too much* IRB Developments rebuild: Project Ice cube 2012-forever (most likely!) Daily drives: Mercedes E250cdi E Class estate, Modified Skoda Yeti, 05 Honda Jazz for those short runs! http://www.defender2.net/forum/topic11056.html Last edited by Yorkshire90 on 8th Jul 2015 1:16pm. Edited 2 times in total |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Some R380 boxes also have a talered torx plug too.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
Cheers, got a Torx T55 bit for the R380.
Just wondering if any of the axles are different etc. I'll get cracking then ![]() SOLD Discovery 3 TDv6 GS Auto 2011-2012 *Missed the Defender too much* IRB Developments rebuild: Project Ice cube 2012-forever (most likely!) Daily drives: Mercedes E250cdi E Class estate, Modified Skoda Yeti, 05 Honda Jazz for those short runs! http://www.defender2.net/forum/topic11056.html |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
The engine does have a sealing washer, this should be replaced.
Regards Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
Already serviced the engine with a new washer with a magnetised Femco drain plug.
It's only the axles and other boxes I'm doing next ![]() SOLD Discovery 3 TDv6 GS Auto 2011-2012 *Missed the Defender too much* IRB Developments rebuild: Project Ice cube 2012-forever (most likely!) Daily drives: Mercedes E250cdi E Class estate, Modified Skoda Yeti, 05 Honda Jazz for those short runs! http://www.defender2.net/forum/topic11056.html |
