Home > Maintenance & Modifications > Washers? Loctite blue? TD5 axles / R380 / T-Box
Yorkshire90
For the final part of my 90's service I'm changing the oils throughout.
1) Do any of the axles have copper washers like the sump that need renewing?
2) Do the R380 or Tbox?
3) Just used some loctite blue on the Femco drainplug I installed on the engine sump. Is it worth adding a bit of loctite to any the above?
Cheers Thumbs Up SOLD "Big green" 2000 Td5 90 IRB Developments modified (2004-2011)
SOLD Discovery 3 TDv6 GS Auto 2011-2012 *Missed the Defender too much*
IRB Developments rebuild: Project Ice cube 2012-forever (most likely!)
Daily drives: Mercedes E250cdi E Class estate, Modified Skoda Yeti, 05 Honda Jazz for those short runs!
http://www.defender2.net/forum/topic11056.html
Post #436435 7th Jul 2015 10:50pm
grumpy old git
1) no, the drains are tapered and torqued up.
2) the R380 has a copper washer, transfer box is tapered and torqued up.
I've never used Loctite, some hylomar blue sealant is recommended but there's no real need IMO.
(EDIT: Corrected name of sealant.)
Post #436448 8th Jul 2015 12:17am
rallysteve
Some R380 boxes also have a talered torx plug too.
Post #436456 8th Jul 2015 7:55am
Yorkshire90
Cheers, got a Torx T55 bit for the R380.
Just wondering if any of the axles are different etc. I'll get cracking then Smile Ta. SOLD "Big green" 2000 Td5 90 IRB Developments modified (2004-2011)
Post #436509 8th Jul 2015 12:46pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
The engine does have a sealing washer, this should be replaced.
Regards
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #436515 8th Jul 2015 1:06pm
Yorkshire90
Already serviced the engine with a new washer with a magnetised Femco drain plug.
It's only the axles and other boxes I'm doing next Thumbs Up SOLD "Big green" 2000 Td5 90 IRB Developments modified (2004-2011)
Post #436517 8th Jul 2015 1:16pm
