Home > Technical > Touch screen install into dash
Page 1 of 3 123>
AndrewS
Its started. The brackets have been made to house the in car PC, removed the dash to get access allow the wiring and brackets to mount the touch screen into the dash.
Ever wondered what your defender looks like without the dash in.
 130's have feeling's as well you know Smile
Post #43346 23rd Oct 2010 8:30am
mse
Andrew
Looks like an interesting project.
If you have 5 minutes, would you mind sharing any pics of the dash removed? When the dealers removed mine they moved some stuff i put in, so i wanted to try and formulate a plan of action Thumbs Up Mike
Post #43348 23rd Oct 2010 8:35am
ibexman
Andrew youre a brav man Shocked Shocked
Post #43372 23rd Oct 2010 12:20pm
discocuzzy
Just started mine as well Andrew Thumbs Up , im mounting a compact car pc in the mobile storage cubby box base, routing the Liliput cables up the back of the dash and have the 10" touch screen on a quick release conector on the ledge just in front of the clock Thumbs Up .
The pc will have all my navigation (road and offroad), itunes, mobile tinterweb and dvds loaded Thumbs Up
Pics very soon, your a brave man taking the lot out!! You cannot teach stupid people to do clever things
Post #43380 23rd Oct 2010 2:17pm
What sort of screen are you fitting?
I've got a LinITX 10.2" in my 110. works a treat. although I fitted a 12" to a friends 90,which is slightly better to look at for emails/web surfing, the 10" works brilliantly with mem map.
With a RAMmount:
Post #43392 23rd Oct 2010 6:21pm
AndrewS
Got the screen in today. Not finished proper as J-Lo has to go to London tomorrow Twisted Evil
Screen in the folded position.
Big Cry Sorry about the blurred pic, the screen in the upright position. It can be tilted to any angle. Sat 5 of us in the car and everyone can see the screen Thumbs Up .
Post #43577 26th Oct 2010 7:04pm
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
looks good Andrew, Can you tilt it towards drivers side or is vision ok. Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #43583 26th Oct 2010 7:25pm
Looking good
What are you using for the PC bit? i've got one of the voomPC2 boxes, and highy reccomend them.
I've built several for friends and they all work AOK (in fact, i'm just upgrading my motherboard to speed it up a bit)
Post #43585 26th Oct 2010 7:26pm
AndrewS
Was going to make a left right swivel but no need its very easy to see from all seats TF Wink
Got a friend that built the PC for some favours Thumbs Up 130's have feeling's as well you know Smile
Post #43586 26th Oct 2010 7:27pm
Eduardo
AndrewS,
Really impressive picture of the open dash and the screen looks Thumbs Up
Just 2 questions
How did you manage the air outlets that were located behind the screen?
Any problem when you turn on the heater with the screen?
Cheers Eduardo
Post #43588 26th Oct 2010 8:00pm
AndrewS
diesel_jim wrote:
Looking good
Intel E8400 Core 2 Duo processor (with Silverstone NT07-775 cooler) on a Zotac GF9300-I-E motherboard with 4GB of Crucial Ballistix RAM, 500Gb Seagate Momentus 7200.4 SATA 3GB/s hard drive (with G-Force Protection technology). All installed in a LinITX CarPC Chassis with a M2-ATX 160W Intelligent Car PSU and with an external LG GE20NU11 DVD drive. Running Windows 7 Home Premium 64bit. It will also have an Archos 7 plugged into it Thumbs Up
Eduardo wrote:
AndrewS,
Just 2 questions
Any problem when you turn on the heater with the screen? Cheers
My plan was to re-direct the air to the second row seats, however this proved impossible so they have been blanked off. The two circular directional vents and the two rectangular vents are all fed from the same outlet so no big deal.
The two rectangular vents operate (blow) when the AC in turned on even if the fan is turned off. I have cut a few holes on the outlet manifold to allow this air to escape behind the dash if the circular vents happen to be closed. 130's have feeling's as well you know Smile
Post #43590 26th Oct 2010 8:17pm
Nice spec! Thumbs Up Thumbs Up
I've got that M2-ATX PSU as well, works well.
Archos7..... Rolling with laughter is that in case anyone in the back gets bored of what you're showing in the front? Rolling with laughter Thumbs Up Thumbs Up
I'm only running XP on mine, mainly for memory map, microcat and other tech stuff, with a simple wifi dongle on the rollcage for picking up hotspots (then saving them on MM... Whistle Whistle ) handy for parking up and checking emails or forums Laughing Laughing
Post #43596 26th Oct 2010 8:39pm
mse
Is there a good covert case to store the PC? Mike
Post #43619 26th Oct 2010 11:04pm
discocuzzy
Inside a mobile storage cubby box with a false fitted above it, takes up about 3-4" of cubby box depth but still loads of useable space Thumbs Up You cannot teach stupid people to do clever things
Post #43625 26th Oct 2010 11:34pm
Slimer
What's the airflow like around the PC if you fit it like that Steve?
Enough for it to stay cool in the desert?
Post #43635 27th Oct 2010 8:31am
Page 1 of 3 123>
