Home > Td5 > Engine hesitating and then into Limp Mode |
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 |
Did the garage "suggest" replacing the injector loom?
If there is oil at the ecu, it WILL need replacing, the engine loom will need cleaning ecu end and injector end, and keep cleaning it over a period of a couple of weeks until all the oil is out. The ecu may also need a clean out. As for the TPS fault, that's self explanatory. It wasn't me! |
18th Jun 2015 6:14pm |
WorcsTD5 Member Since: 01 Feb 2014 Location: Worcester Posts: 23 |
This just in:
Mechanic has swapped the ECU and the throttle sensor (from another Defender TD5) and its still showing the fault. He said the MAF sensor needed changing but that wouldn't cause it to go to limp mode. He's done a line check on the cable from throttle to ECU and that seems OK. He also said that he had a similar problem a while ago that turned out to be a faulty plug at the throttle sensor so he's going to have a look at that. He's keeping the Defender over the weekend and an auto-electrician is coming in on Monday to cast an expert eye over it. I've got a courtesy car so I'm still mobile Just relieved that it doesn't appear to be the ECU that's at fault... |
19th Jun 2015 2:35pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Do you have a cruise control system fitted? I had a little different problem. It sometimes suddenly lost any reaction off the throttle. I made a on off switch for the Cruise controll system and from that moment I didn't have the problem anymore. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
19th Jun 2015 6:25pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
ECU faults are no problem anyway I had one with the same fault a while ago, I can't remember if the fault was the harness plugs by the clutch master cylinder on the bulkhead or if I just rewired the throttle potentiometer from the pedal to the ECU....... |
19th Jun 2015 9:51pm |
Turns out one of the wires had separated from a pin in the throttle assembly plug.
Found by chance and soldered to within an inch of its life...! Fingers crossed... |
29th Jun 2015 10:03am |
