![]() | Home > Puma (Tdci) > Dead gearbox |
No drive or no gears?
http://www.defender2.net/forum/topic32931.html?highlight=gears If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
adaptor shaft splines , as in k9f's link
andy65 Member Since: 01 Dec 2013 Location: Hampshire Posts: 14 ![]() ![]() ![]() |
Hi k9f
Thank u for ur reply. Sorry to sound really dumb but I have not idea of the difference. Looking at the link, it seems like a regular problem with the spline? I drew upto the lights at bottom of a34, came down through the gears, stopped, went to pull away and clunk!! Andy |
transfer box jumped in to neutral ?
any noises from it when you try to drive ? any extra noises from gearbox before it went , like clunking when changing gear ? does the lever feel the same as before when you select gear ? |
Hi muncho
Appreciate ur response Yes, it seemed to jump into neutral I thought I had heard a bit of a rattle earlier on the drive home but thought it was me! First time it clunked into gear was at the traffic lights. If I try to select a gear now, it whirls but won't go into a gear! regards |
Whoops sorry
Munch90, not muncho!! ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
Do you mean that you can't move the gear lever into gear (=broken clutch or gearbox) or that the gear lever and clutch seem to work normally but when you put it in any gear and come off the clutch you get the noise but the vehicle doesn't move? If the latter, it's most likely to be the output adaptor shaft, but could be a halfshaft, drive flange or diff failure, or it could be a transfer box problem. If you can be more specific we can probably provide a narrower diagnosis. |
Cheers Blackwolf
Yes, it seems to be the latter... If I put it into 1st gear, there is a whirling noise but won't move, same for 2nd etc and the noise is increased/ sped up!! Bit of a worry as booked up to travel down to Italy in her with family in 4 weeks!! Regards |
Not a worry. Dealer fix under warranty......Sorted! Better it happened now rather than in four weeks one days time.
![]() Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 28th Jun 2015 11:58am. Edited 1 time in total |
Have you tried moving the hi/lo selector ? Ray
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 ![]() ![]() ![]() |
Almost certainly another adapter shaft spline failure.
Yes totally agree K9F, would have had hours of fun explaining problems in my perfect French and Italian accents!!!!
![]() Would have been a Basil Fawlty moment...... Yes, tried the hi/lo selector... No go!! By the sounds of it Scoobeenut, find out 2mo hopefully |
H Member Since: 14 Sep 2015 Location: bristol Posts: 1 ![]() ![]() |
We have a 2012 defender. The gear box has just developed its third fault/failure in three years!!
Luckily still in warrenty-just! L.R will be getting a phone call from me............ |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
If you get the shaft replaced under warranty make sure you mention to get it lubricated / greased once fitted too.
You don't want a new one fitted under warranty not greased and then it fails out of warranty. They would like that. ![]() |
