Page 823 of 1394 <123 ... 822823824 ... 139213931394>
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Well done Hairysteve. Now the L/R bug has bitten, you will realise it has big teeth. S/S bolts is something I have been meaning to get round to, but doing a lot of work on the house just now. Keep on doing a wee bit at a time and soon you will have the motor you always wanted - almost, as there is always a wee bit more to be done Laughing
Post #433921 26th Jun 2015 11:00pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Thanks RoddyK05, the list of mods (aspirations) is growing fast Rolling with laughter
Post #433948 27th Jun 2015 7:21am
ericvv
Hairysteve wrote:
Did my first bit of work on my first LR, replaced all the door bolts with stainless steel ones Razz
Which anti-corrosion paste did you use on the stainless steel bolts? You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #433950 27th Jun 2015 7:33am
Hairysteve
Hi there, I used the one that came with the SS set, Berner Anti-Seize paste.
Post #433955 27th Jun 2015 8:01am
Hairysteve
You have me thinking about how much paste I should of used on each bolt, mmmm. I smeared a fine film down the length of each bolt. Any thoughts/suggestions?
Post #433956 27th Jun 2015 8:05am
red zepplin
1998 Defender 90 300 Tdi HT Rioja Red
today got my windscreen washer working again (note to self check non return valve BEFORE removing dash board top) Banging Head
Post #433983 27th Jun 2015 10:38am
shaggydog
Sorted my wiring issue which kept blowing my spotlight loom fuse.
Turns out when I moved it I had reversed 2 plugs so when triggered it was sending mains voltage to earth Shocked
Tracked down a rattle in the back which was being caused by a rattly step and then thought about cleaning it but decided to water the garden and do some weeding instead! Thumbs Up
I have got photos to stick up in my rolling restoration thread of putting in a red bison loom but as my laptop screen is dead on one side it makes it very difficult! Big Cry Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #434051 27th Jun 2015 4:35pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
Been a busy boy today fitting:
Washer bottle cap
Upper waist seals
front door rubber seals
back mudflaps with stainless bolts
led side indicactors from leeds and stainless guards to protect them 2004 TD5 Defender 90 xs station wagon
Post #434090 27th Jun 2015 7:52pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
Yesterday: after 11 years and a quarter of a million miles it was the first time the door catch tore the rear pocket of my jeans.
Spent the afternoon at work pulling my t-shirt down over the hole... Rolling with laughter Dave
Green Goddess - 1998 Defender 110 300tdi
Post #434102 27th Jun 2015 8:24pm
srod
Had a fun day towing my boat, maybe even more fun than sailing it:
Post #434108 27th Jun 2015 8:56pm
YOLO110
Australia
Thats a bloody big grey fender you have for it mate! Laughing YOLO... You Only Live Once...
Post #434158 28th Jun 2015 1:37am
fathaggis
finally got my led spots set with main beam Thumbs Up
Post #434262 28th Jun 2015 2:13pm
mk1collector
Not today but all day yesterday, took a 12 hour round trip to Wales to look at something special Mr. Green hopefully more details in the next week or two Whistle defender worked perfectly the whole 450 miles and only my head ache from me probably needing a new glasses prescription for the last half an hour caused any negative Cool Ray
My build thread
Post #434264 28th Jun 2015 2:18pm
Vitesse
Finally fitted a blue sea fuse box next to the fuses under the seat, and linked to the battery box with flexible conduit. Will be wiring up another day. Additional electrical mods to follow. Thumbs Up 2015 90 XS Santorini Black
Post #434352 28th Jun 2015 8:11pm
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Removed the window blocks from the truck and added silicone sealant to the gaskets. Also added silicone sealant to the windscreen seal, I essentially added a bead of silicone to the sponge on the outside.
Gave it 30mins and then out with the hose, still a few leaks, but played with the vent flap and eventually no leaks (today).
So I think I have cured the window block leaks, and mitigated or cured the windscreen seal leak.
I need to remove the vent flaps and fit new seals to the flaps, that way I will have mitigated another leak point.
Andy
Post #434408 28th Jun 2015 10:40pm
