![]() | Home > Technical > hi lo revs switch |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
As some kind of guide would have say engaging hi is easier or more difficult than diff lock?
Sorry dont know what your asking
![]() As some kind of guide would you say engaging hi is easier or more difficult than engaging diff lock? Might be irrelevant now anyway. I've been consciously engaging hi/lo and confident it's engaging ok. as mentioned above you can feel (I presume) the spring balls being doing there thing. front prop is back in and things running slightly better but before it went back there was some big 'CLANK' moving from gear into neutral and 'CLANK' neutral back into gear? and pulling away in 1st can be nice and smooth or as tonight about 2k rpm - clatter clatter WTF can it be. ![]() ![]() |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
The more you blindly fiddle the deeper in the mire you are going to get. Get someone off the forum who is familiar with 2.4 Puma's to drive it. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
+1
could be just gear clatter , maybe one reason why fords fitted dmf 's on light throttle , hardly any load gears can clatter as your talking about a transfer box of basically 40yrs old design |
![]() + another 1. Please FFS! ![]() Treat every day as if it is your last....one day you will be right!! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18034 ![]() ![]() ![]() |
Have you tried taking both propshafts off at the same time? You'll find it is quite smooth then.
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
if you drive faster you can't hear all these noises. Amazing how long these threads are about one mans 110.
