Home > Technical > hi lo revs switch
Page 5 of 5 <12345
munch90
Miserableolgit wrote:
Aha, so this is why my ears have been burning!!!
Partial engagement by yours truly was the cause of the additional backlash and also why the transfer box jumped out of gear while under power as I pulled pretty smart-ish out from a junction. To put it simply the selector shaft was not fully engaged in the detent. I recall the vehicle was virtually new at the time and the ratio lever quite stiff, component wear or non factory adjustment did not enter the equation.
I have delved into enough Land Rover transfer boxes over the years and they are simple enough to understand, bar fluid checks and changes all the ones in Puma's I've owned have remained virginal when it comes to any delving on my part though Wink
ive had and seen the same thing happen lots of times and always found best way to change hi/lo -lo/hi , is to move lever keep slight pressure on lever move few feet and 9 times out of 10 it will go in gear bit further
as said there a quite course toothed dog gear so sometimes need a help hand to get right in
Post #433404 24th Jun 2015 7:23pm
Caterham
As some kind of guide would have say engaging hi is easier or more difficult than diff lock?
Post #433430 24th Jun 2015 9:25pm
munch90
Sorry dont know what your asking
Post #433431 24th Jun 2015 9:28pm
Caterham
Confused oops - I'll try again.
As some kind of guide would you say engaging hi is easier or more difficult than engaging diff lock?
Might be irrelevant now anyway. I've been consciously engaging hi/lo and confident it's engaging ok. as mentioned above you can feel (I presume) the spring balls being doing there thing.
front prop is back in and things running slightly better but before it went back there was some big 'CLANK' moving from gear into neutral and 'CLANK' neutral back into gear?
and pulling away in 1st can be nice and smooth or as tonight about 2k rpm - clatter clatter
WTF can it be. Big Cry having run with front prop out it's not the front axle and having had the rear prop out I'm sure its not the rear axle either. Big Cry
Post #433469 24th Jun 2015 11:14pm
Happyoldgit
The more you blindly fiddle the deeper in the mire you are going to get. Get someone off the forum who is familiar with 2.4 Puma's to drive it. Steve.
http://forums.lr4x4.com
Post #433532 25th Jun 2015 10:12am
munch90
could be just gear clatter , maybe one reason why fords fitted dmf 's
on light throttle , hardly any load gears can clatter as your talking about a transfer box of basically 40yrs old design
Post #433536 25th Jun 2015 10:19am
K9F
Thud
+ another 1. Please FFS! Bow down If you go through life with your head in the sand....all people will see is an ar5e!!
Post #433554 25th Jun 2015 11:23am
Have you tried taking both propshafts off at the same time? You'll find it is quite smooth then.
Post #433606 25th Jun 2015 2:40pm
RobKeay
if you drive faster you can't hear all these noises. Amazing how long these threads are about one mans 110.
Post #433640 25th Jun 2015 7:58pm
Page 5 of 5 <12345
