Home > Maintenance & Modifications > removing the stearing wheel
67_6Cyl
France
I'm after a magic tip / trick.
I am trying to remove the steering wheel to replace the indicator / dim / dip / horn switch.
It looks like the steering wheel has been fixed onto the splined steering column with threadlock, or at least wanged on far too tight.
I have made a puller bar that screws into the two M6 threads either side of the boss, and pushes on the splined inner column. All that this did was manage to bend a piece of 1/4 inch thick steel, and not remove the wheel from the splines. - I have also soaked it in WD40 and PlusGas, without any effect.
Help. Any ideas as to how to remove the wheel from the column?
Thanks
Jon
Post #433291 24th Jun 2015 12:13pm
scotia
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Have you tried thumping the front of the wheel on alternate sides a few times - this usually works.. If not use and even thicker piece of steel for your puller and a hefty blow with a hammer on the end of the centre bolt head whilst it is under maximum tension.
Post #433294 24th Jun 2015 12:27pm
gilarion
Probably not a great help but I mention this just in case you are having the same problem as I once had.
I had the same difficulty with a steering wheel and no matter what I did I could not remove it. Turned out some nutter had hammered a 36 spline wheel onto a 48 spline shaft to get it to fit. Ended up having to cut the wheel off and replace the column. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #433295 24th Jun 2015 12:27pm
X4SKP
Hello 67_6Cyl
I had a similar problem, mine had a Startech Steering wheel fitted which was 1 spline out in alignment... Shocked
and was also really tightly engaged onto the splines.
I used a Puller to apply an even force to the Boss...which is the key here (I would suggest)...
You think it's not going to move and then it releases,
just take your time and check for true alignment as you go... Thumbs Up
As you can see I took the Steering wheel off the Boss in order to do this
Good Luck
 SKIP
Post #433297 24th Jun 2015 12:33pm
grafty99
Nothing wrong with an accurate and proportional blow with a hammer if all of the above fail (using the puller in combination) 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #433301 24th Jun 2015 12:48pm
Use a bigger/stronger puller.
You don't actually need to get the wheel off to do what you need, it is possible to remove the switch from the mounting plate and swap it over. You have to be careful as there are springs and small parts which can fall out, but it is possible - I have done it in the past on my 2.4.
Post #433309 24th Jun 2015 1:18pm
nitram17
Re: removing the stearing wheel
Thanks
Jon
Have you tried holding it at 12 and 6 then 3 and 9 rocking back and forward frequently dont try to pull but rock it as this may loosen it...then pull!
Post #433395 24th Jun 2015 6:37pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
All good advice.
The only thing I would add is,leave the center nut on a few threads,then if it comes free whilst your pulling / banging it,it wont smack you in the face.
Bonne chance.
Marc
Post #433407 24th Jun 2015 7:53pm
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
!!!!! Remember to leave the nut on the top of the thread when pulling/banging!!!
How many of us have had a steering wheel in the face?!? Banging Head
Thumbs Up
EDIT...30 seconds too late ^^^^^^^^^^^^^^^^^^
Clemmo Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion 17k miles
Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun
Post #433409 24th Jun 2015 7:54pm
67_6Cyl
France
cheers guys.
I have tried the rocking and hammering, but without success - but I did keep the nut on, just in case.
I have now ordered a proper steering wheel puller.
Best
Jon
Post #433548 25th Jun 2015 11:06am
Martin
Site Admin
Ensure the puller you use puts pressure on the column, not on the 2 M6 threads.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #433567 25th Jun 2015 12:05pm
67_6Cyl
France
Done!
Quick warning, it turned out that the threads in the central boss to pull from were 1/4 UNF not M6........
Built in 2007..... And still a mix of UNF and metric.......
Jon
Post #437260 12th Jul 2015 5:42pm
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
Thanks
Jon
I've also made my own puller. 18mm A/F hex bar, 6mm bolts as per and an m12 bolt through the centre. Works every time, and you won't bend it. It wasn't me!
Post #438056 15th Jul 2015 6:43pm
Laurie
Completely slacken the nut. Lock the tab to stop it coming undone anymore.
Then drive it 'til it comes loose. Won't take long. (Especially on potholed roads Rolling Eyes )
Post #438058 15th Jul 2015 6:49pm
